I have a Panasonic FZ-55 with an EM7511 wireless card installed. I have updated all the drivers/bios for the Panasonic and the Sierra card and I am still unable to connect to the Verizon Network. I have spoken to Verizon and they told me the SIM card was not seen by the network, so I installed it in my phone and was able to activate it that way. When I open the cellular connections, I am not seeing any APN settings and under Network it just says Verizon Wireless No Service for the card. Don’t know what step I should take next to get this card working.
What is thd return of followkng AT command?
Ati3
At!entercnd=“A710”
At!gstatus?
At!impref?
Got it. Had to use Putty. Here are the results.
ATI3
Model: EM7511
Revision: SWI9X50C_01.14.02.00 2e210b jenkins 2020/08/19 14:18:39
IMEI: 990008270776466
IMEI SV: 12
FSN: YT051588080410
+GCAP: +CGSM
AT!entercnd=“A710”
At!gstatus?
!GSTATUS:
Current Time: 416 Temperature: 34
Reset Counter: 1 Mode: ONLINE
System mode: LTE PS state: Not attached
LTE band: B2 LTE bw: 15 MHz
LTE Rx chan: 1125 LTE Tx chan: 19125
LTE SCC1 state:NOT ASSIGNED
LTE SCC2 state:NOT ASSIGNED
LTE SCC3 state:NOT ASSIGNED
LTE SCC4 state:NOT ASSIGNED
EMM state: Deregistered Attach Needed
RRC state: RRC Idle
IMS reg state: No Srv IMS mode: Normal
PCC RxM RSSI: -93 PCC RxM RSRP: -133
PCC RxD RSSI: -58 PCC RxD RSRP: -90
Tx Power: – TAC: 7307 (29447)
RSRQ (dB): -13.2 Cell ID: 083f9708 (138385160)
SINR (dB): 0.4
At!impref?
!IMPREF:
preferred fw version: 01.14.02.00
preferred carrier name: VERIZON
preferred config name: VERIZON_002.039_000
preferred subpri index: 000
current fw version: 01.14.02.00
current carrier name: VERIZON
current config name: VERIZON_002.039_000
current subpri index: 000
How about these?
at!UIMS?
At+cpin?
At+cfun?
At+cgdcont?
AT!entercnd=“A710”
at!SELRAT?
AT!BAND?
Here’s the problem I’m having now. I uninstalled and updated the drivers for the device again and now I’m getting this alarm when I’m trying to query the modem.
I went ahead and changed my Putty to COM 9 and this was the response I received back from the device. I don’t know if this was going to the modem or not.
+CPIN: READY
at+cfun?
at+cfun?
+CFUN: 1
at+cgdcont?
at+cgdcont?
+CGDCONT: 1,“IPV4V6”,“ims”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IPV4V6”,“vzwadmin”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,“vzwinternet”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 4,“IPV4V6”,“vzwapp”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 5,“IPV4V6”,“vzw800”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 6,“IPV4V6”,“vzwclass6”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 7,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
AT+cpin?
+CPIN: READY
Com9 is nmea, not modem port
is there any windows software with Gui to use these modules and their gps etc?
how about this?
ok, but what about the Gps apps
How about Skylight GPS Monitor?
ok, but apps for windows 7?
Can you install skylight in win7?
i managed to unpack the appx file now, but the exe is not even launching at all
other users can make it work in win7:
ok, that might be airprime, but win10 has the separate skylight app in the app store.
the airprime does not detect any card tho… i checked that the 5087 0005 driver package is already installed…
what is the
at!ENTERCND=“A710”
AT!USBCOMP?
Does your module work with WIN10 with skylight?
well, now i managed to reinstall the drivers somehow and now it actually gives me com ports to use, but what should the baud rate be and which port could be which and what rate for each also?
i ony get this with 115,2k and 9,6k:
Invalid or no response from the device. Please check the modem port and the baud rate.Disconnecting port COMx
ok, now i downloaded that special sierra atcommand app for 7 days or smth, but which commands should i run then.
and it also suggested to connect with some flow control somewhere…
You can use tera term to open the modem port to type AT command
ok i try that, but the sierra at app also gives this error:
No NMEA data found in COMx. Please check the NMEA port…
what speeds should i use tho and what is the DM port?
