I’m running GoldenOrb on a router and am having problems getting the EM7565 to connect to Verizon. The SIM works fine when I put it in an Android phone.
ati
Model: EM7565
Revision: SWI9X50C_01.08.04.00 dbb5d0 jenkins 2018/08/21 21:40:11
IMEI: 353533100178600
IMEI SV: 8
FSN: UF921274190215
+GCAP: +CGSM,+DS,+ES
AT+CPIN?
+CPIN: READY
AT!IMPREF?
!IMPREF:
preferred fw version: 01.08.04.00
preferred carrier name: VERIZON
preferred config name: VERIZON_002.015_001
current fw version: 01.08.04.00
current carrier name: VERIZON
current config name: VERIZON_002.015_001
AT+COPS?
+COPS: 0
AT+CGDCONT?
+CGDCONT: 1,“IPV4V6”,“VZWINTERNET”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IPV4V6”,“vzwadmin”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,“vzwinternet”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 4,“IPV4V6”,“vzwapp”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 5,“IPV4V6”,“vzw800”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 6,“IPV4V6”,“vzwclass6”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
AT!GSTATUS?
!GSTATUS:
Current Time: 5304 Temperature: 23
Reset Counter: 3 Mode: ONLINE
System mode: LTE PS state: Not attached
LTE band: B2 LTE bw: 20 MHz
LTE Rx chan: 800 LTE Tx chan: 18800
LTE SSC1 state:NOT ASSIGNED
LTE SSC2 state:NOT ASSIGNED
LTE SSC3 state:NOT ASSIGNED
LTE SSC4 state:NOT ASSIGNED
EMM state: Deregistered Limited Service
RRC state: RRC Idle
IMS reg state: No Srv IMS mode: Normal
PCC RxM RSSI: -70 PCC RxM RSRP: -102
PCC RxD RSSI: -67 PCC RxD RSRP: -99
Tx Power: – TAC: 8b43 (35651)
RSRQ (dB): -12.4 Cell ID: 0a135209 (169038345)
SINR (dB): 5.4
