EM7565 shows Verizon -no service
Using EM series USB devikit. First of all who knows which Antennas to plug in. there are 5!!
I only need LTE functionality so plugged in ANT0 and ANT(Main)
on Windows 11 its detecting the modem and the sim (Verizon) too.
But it shows Verizon(no service) in Windows network manager
I have even downloaded the FW from Sierra support
What is the return of at!gstatus? In modem port
at!gstatus?
!GSTATUS:
Current Time: 2082 Temperature: 24
Reset Counter: 5 Mode: ONLINE
System mode: WCDMA PS state: Not attached
WCDMA band: No band
WCDMA channel: 4294967295
GMM (PS) state:DEREGISTERED NO SERVICE
MM (CS) state: IDLE NO SERVICE
WCDMA L1 state:L1M_DEEP_SLEEP LAC: 0000 (0)
RRC state: DISCONNECTED UTRAN Cell ID: 00000000 (0)
RxM RSSI C0: — RxD RSSI C0: —
RxM RSSI C1: — RxD RSSI C1: —
Does it work with other operator like tmo or ATT?
Tried it with ATT and didnt work. Even tried it with Verizon sim that works on different vendor (Quectel) module and even that one didnt work
Are you using the correct PRI file when using different operator?
seems nothing is working with your EM7565…
not sure AT!RMARESET to reset the module can help…
I have only downloaded the vendor provided FW files from Sierra. I just looked at CGDGONT to see if it has the right APN. Not sure how to use the correct PRI file. Where can I find instructions to do that?
you can download the exe here:
https://source.sierrawireless.com/resources/airprime/minicard/75xx/em_mc75xx-approved-fw-packages/#sthash.RMay2Poi.dpbs
I re downloaded this. It successfully flashed. But still same issue. I feel somehow the correct APN is either not being applied or the antennas are not plugged in properly for connectivity. (right now there is one on ANT0 and ANT(MAIN))
What can I share to help debugging?
You can check the signal strength in at!gstatus?
at!gstatus?
!GSTATUS:
Current Time: 9246 Temperature: 25
Reset Counter: 3 Mode: ONLINE
WCDMA band: No band
I think your antenna has some problem, in my test, even it is not registered to network, it should have some RSSI value:
at!selrat=0
at+cfun=0
at+cfun=1
at!lteinfo
!LTEINFO:
Serving:   EARFCN MCC MNC   TAC      CID Bd D U SNR PCI  RSRQ   RSRP   RSSI RXLV
             2460 454  06 10101 016E8A49  5 3 3  15 437 -12.3  -88.2  -58.9  34
IntraFreq:                                          PCI  RSRQ   RSRP   RSSI RXLV
InterFreq: EARFCN ThresholdLow ThresholdHi Priority PCI  RSRQ   RSRP   RSSI RXLV
WCDMA:     UARFCN ThreshL ThreshH Prio PSC   RSCP  ECN0 RXLV
at!gstatus?
!GSTATUS:
Current Time:  231              Temperature: 30
Reset Counter: 1                Mode:        ONLINE
System mode:   LTE              PS state:    Not attached
LTE band:      B5               LTE bw:      10 MHz
LTE Rx chan:   2460             LTE Tx chan: 20460
LTE SCC1 state:NOT ASSIGNED
LTE SCC2 state:NOT ASSIGNED
LTE SCC3 state:NOT ASSIGNED
LTE SCC4 state:NOT ASSIGNED
EMM state:     Deregistered     Attaching
RRC state:     RRC Idle
IMS reg state: No Srv           IMS mode:    Normal
PCC RxM RSSI:  -59              PCC RxM RSRP:  -86
PCC RxD RSSI:  -99              PCC RxD RSRP:  -135
Tx Power:      --               TAC:         2775 (10101)
RSRQ (dB):     -10.3            Cell ID:     016e8a49 (24021577)
SINR (dB):      8.4
ati3
Model: EM7411
Revision: SWI9X50C_01.14.20.00 d3bef3 jenkins 2022/08/08 03:22:57
IMEI: 356280111412345
IMEI SV: 14
FSN: 8F224126812345
+GCAP: +CGSM
at!impref?
!IMPREF:
 preferred fw version:    01.14.20.00
 preferred carrier name:  VERIZON
 preferred config name:   VERIZON_002.058_000
 preferred subpri index:  000
 current fw version:      01.14.20.00
 current carrier name:    VERIZON
 current config name:     VERIZON_002.058_000
 current subpri index:    000
I am using the EVB can you tell me which antennas you have populated. I am using the antennas from the box
i connect the main antenna only
I am getting LTE not avaialble for some reason. I tried both the sims right now. ATT and Verizon
at!lteinfo
!LTEINFO:
Not Available
ATT:
ati3
Model: EM7565
Revision: SWI9X50C_01.14.22.00 ba8ef1 jenkins 2022/11/11 09:59:48
IMEI: 359260080929521
IMEI SV: 15
FSN: UF203203070310
+GCAP: +CGSM
How about doing at+cfun=0 and at+cfun=1 ?
This is from my testing:
at+cfun=0
at+cfun=1
at!lteinfo
!LTEINFO:
still no luck
at+cfun=0
at+cfun=1
at!lteinfo
Unavailable
at!lteinfo
!LTEINFO:
Not Available
at!lteinfo
!LTEINFO:
Not Available
ati3
Model: EM7565
IMEI SV: 14
FSN: UF203203070310
+GCAP: +CGSM
ERROR
at!impref?
!IMPREF:
Changing the antenna cable helped getting connection back. However when I try connecting my laptop to the LTE network it gives an error that cell service isnt working properly
ati3
Model: EM7565
IMEI SV: 14
FSN: UF203203070310
+GCAP: +CGSM
at+cfun=0
at+cfun=1
at!lteinfo
!LTEINFO:
5230 311 480 7942 0079B901 13 3 3 18 36 -14.6 -80.8 -50.9 –
2075 0 0 0 36 -14.5 -91.1 -68.8 0
1150 0 0 0 36 -12.7 -98.0 -77.5 0
what is the latest value of AT!GSTATUS?
THIS:
at!gstatus?
!GSTATUS:
Current Time: 403 Temperature: 25
Reset Counter: 2 Mode: ONLINE
LTE band: B66 LTE bw: 15 MHz
LTE Rx chan: 66561 LTE Tx chan: 132097
RRC state: RRC Idle
IMS reg state: Full Srv IMS mode: Normal
PCC RxM RSSI: -58 PCC RxM RSRP: -90
PCC RxD RSSI: -93 PCC RxD RSRP: -131
Tx Power: – TAC: 1f06 (7942)
RSRQ (dB): -13.7 Cell ID: 050d990c (84777228)
SINR (dB): 13.6
