I have a long pain to let my AT&T sim card work with em7455. At first, install recent em7455 driver with PC, showed and detected perfect “sierra wireless em7455” under driver manger. But no service and connection got. ATT sim card information and telephone number can be seen from mobile network property, the same issue even with skylight install ed. I guess the problem still come from EM7455. My att sim tested in ipad has service and connection. But while it put into adapter directly connect to USB port of Window10 PC, no cellar service and connection.let em7455 switch to generic FW and MBIM mode. tested again and no service still got.100% sure that em7455 is under generic FW, right ATT APN and Mibm mode. no problem to detect em7455 with device manager, every com port open, ATi communication works. . So strange!
Including the following em7455 configuration from AT commands
ATT apn is “broadband”, I put
at+cgdcont=1,“ipv4v6”,“broadband”
at+cgdcont?
Recieve: +CGDCONT: 1,“IPV4V6”,“broadband”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
at!pcinfo?
Recieve: State: Online
Recieve: LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0
Recieve: LPM persistence - None
AT!PCOFFEN?
Recieve: 0 (“0” = Modem will enter LPM (low power mode) when W_DISABLE is asserted.)
at+cgdcont=?
Recieve: +CGDCONT: (1-24),“IP”,(0-2),(0-4),(0-1),(0-1)
Recieve: +CGDCONT: (1-24),“PPP”,(0-2),(0-4),(0-1),(0-1)
Recieve: +CGDCONT: (1-24),“IPV6”,(0-2),(0-4),(0-1),(0-1)
Recieve: +CGDCONT: (1-24),“IPV4V6”,(0-2),(0-4),(0-1),(0-1)
at!gstatus?
Recieve: Current Time: 859 Temperature: 23
Recieve: Reset Counter: 1 Mode: ONLINE
Recieve: System mode: LTE PS state: Not attached
Recieve: LTE band: B13 LTE bw: 10 MHz
Recieve: LTE Rx chan: 5230 LTE Tx chan: 4294967295
Recieve: LTE CA state: NOT ASSIGNED
Recieve: EMM state: Deregistered Limited Service
Recieve: RRC state: RRC Idle
Recieve: IMS reg state: No Srv
Recieve: PCC RxM RSSI: -97 RSRP (dBm): -137
Recieve: PCC RxD RSSI: -88 RSRP (dBm): -118
Recieve: Tx Power: 0 TAC: F10A (61706)
Recieve: RSRQ (dB): -12.4 Cell ID:
Recieve: SINR (dB): 0.8
at+cfun?
Recieve: +CFUN: 1
my log showed:
Wed Jul 19 00:42:25 2017 daemon.notice netifd: wan1 (2160): swradiostate: off
looks radio didn’t turn on. don’t know why?
