EM7565 shows Verizon -no service
what is the problem now?
I saw that it can attach to network
But doesnt let me connect to the internet. Could be a system issue. I can try a different system also. I will close this ticket as the first issue got resolved
This problem persists… I do not get an IP with the SIM and VErizon shows “NO SERVICE” with EM7565
When I use same SIM With a different vendor LTE module I get instant service
Why you can get attached abobe then?
I have no idea. The message often changes to “No internet” If I do airplane mode on and OFF
Ok this thread helped EM7565 Windows 10 Connects but No Data
Bsaically doing this
at!entercnd=“A710” AT!usbcomp=1,3,100D AT!reset
How do I make this sticky?
this is just to enable AT command port and MBIM port.
Ok so that mean MBIM port is not enabled by default? that is why I wasnt getting Internet?
what is the original setting of AT!USBCOMP? when you first receive this fresh module?
What is the SKU number of this EM7565 module?
SKU: UF2032030703010
I think it was 1,1 fresh module
this is serial number instead of SKU number…
What are the return of the followings?
AT!entercnd="A710"
ati3
AT!sku?
AT!PRIID?
BTW, what is the original setting of AT!USBCOMP? when you first receive this fresh module?
I think your module is in SKU 1103520 and the default value of USBCOMP should be RMNET0 +DIAG + NMEA +MODEM.
So it seems MBIM is not enabled by default
You can double check with a fresh module.
