Modem-manager logs
sudo service ModemManager start
Mar 3 19:14:14 U18 systemd[1]: Starting Modem Manager...
Mar 3 19:14:14 U18 ModemManager[22528]: <info> ModemManager (version 1.10.0) starting in system bus...
Mar 3 19:14:14 U18 systemd[1]: Started Modem Manager.
ak@U18:~$ Mar 3 19:14:14 U18 NetworkManager[1032]: <info> [1614827654.6777] modem-manager: ModemManager now available
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] Opening device with flags 'version-info, proxy'...
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] loaded driver of cdc-wdm port: qmi_wwan
Mar 3 19:14:16 U18 ModemManager[22528]: cannot connect to proxy: Could not connect: Connection refused
Mar 3 19:14:16 U18 ModemManager[22528]: spawning new qmi-proxy (try 1)...
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] Checking version info (10 retries)...
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] QMI Device supports 33 services:
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] ctl (1.5)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] wds (1.67)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] dms (1.14)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] nas (1.25)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] qos (1.6)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] wms (1.10)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] auth (1.3)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] at (1.2)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] voice (2.1)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] cat2 (2.24)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] uim (1.45)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] pbm (1.4)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] test (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] loc (2.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] sar (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] ts (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] tmd (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] wda (1.16)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] csvt (1.1)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] coex (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] pdc (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] rfrpe (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] dsd (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] ssctl (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0x2e] (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0x30] (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0x31] (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0x36] (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] rms (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0xf0] (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0xf3] (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0xf5] (1.0)
Mar 3 19:14:16 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0xf6] (1.0)
Mar 3 19:14:17 U18 ModemManager[22528]: <info> Couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.2/0000:01:00.0': not supported by any plugin
Mar 3 19:14:17 U18 ModemManager[22528]: <info> Couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.4/0000:08:00.0': not supported by any plugin
ak@U18:~$ mmcliMar 3 19:14:31 U18 ModemManager[22528]: <info> [device /sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-5] creating modem with plugin 'Sierra' and '5' ports
Mar 3 19:14:31 U18 ModemManager[22528]: <warn> Could not grab port (tty/ttyUSB1): 'Cannot add port 'tty/ttyUSB1', unhandled serial type'
Mar 3 19:14:31 U18 ModemManager[22528]: <info> Modem for device '/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-5' successfully created
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] Opening device with flags 'version-info, proxy'...
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] loaded driver of cdc-wdm port: qmi_wwan
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] Checking version info (10 retries)...
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] QMI Device supports 33 services:
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] ctl (1.5)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] wds (1.67)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] dms (1.14)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] nas (1.25)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] qos (1.6)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] wms (1.10)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] auth (1.3)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] at (1.2)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] voice (2.1)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] cat2 (2.24)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] uim (1.45)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] pbm (1.4)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] test (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] loc (2.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] sar (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] ts (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] tmd (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] wda (1.16)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] csvt (1.1)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] coex (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] pdc (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] rfrpe (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] dsd (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] ssctl (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0x2e] (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0x30] (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0x31] (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0x36] (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] rms (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0xf0] (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0xf3] (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0xf5] (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] unknown [0xf6] (1.0)
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] Reading expected data format from: /sys/class/net/wwp3s0f0u5i8/qmi/raw_ip
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] Allocating new client ID...
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] Registered 'wda' (version 1.16) client with ID '1'
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] Releasing 'wda' client with flags 'release-cid'...
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] Unregistered 'wda' client with ID '1'
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] Registered 'dms' (version 1.14) client with ID '3'
Mar 3 19:14:31 U18 ModemManager[22528]: [/dev/cdc-wdm0] Registered 'nas' (version 1.25) client with ID '4'
Mar 3 19:14:32 U18 ModemManager[22528]: [/dev/cdc-wdm0] Registered 'wms' (version 1.10) client with ID '3'
Mar 3 19:14:32 U18 ModemManager[22528]: [/dev/cdc-wdm0] Allocating new client ID...
Mar 3 19:14:32 U18 ModemManager[22528]: [/dev/cdc-wdm0] Registered 'uim' (version 1.45) client with ID '3'
Mar 3 19:14:32 U18 ModemManager[22528]: [/dev/cdc-wdm0] Registered 'loc' (version 2.0) client with ID '2'
Mar 3 19:14:34 U18 ModemManager[22528]: <info> Modem: state changed (unknown -> disabled)
Mar 3 19:14:34 U18 NetworkManager[1032]: <info> [1614827674.1962] modem["cdc-wdm0"]: modem state changed, 'disabled' --> 'enabling' (reason: user preference)
Mar 3 19:14:34 U18 NetworkManager[1032]: <info> [1614827674.1974] manager: (cdc-wdm0): new Broadband device (/org/freedesktop/NetworkManager/Devices/17)
Mar 3 19:14:34 U18 NetworkManager[1032]: <info> [1614827674.1977] device (cdc-wdm0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 3 19:14:34 U18 NetworkManager[1032]: <info> [1614827674.1980] device (cdc-wdm0): modem state 'enabling'
Mar 3 19:14:34 U18 NetworkManager[1032]: <info> [1614827674.1988] device (cdc-wdm0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 3 19:14:34 U18 ModemManager[22528]: <info> Modem /org/freedesktop/ModemManager1/Modem/0: state changed (disabled -> enabling)
Mar 3 19:14:34 U18 gnome-shell[1389]: nma_mobile_providers_database_lookup_cdma_sid: assertion 'sid > 0' failed
Mar 3 19:14:35 U18 ModemManager[22528]: <info> Modem /org/freedesktop/ModemManager1/Modem/0: state changed (enabling -> enabled)
Mar 3 19:14:35 U18 NetworkManager[1032]: <info> [1614827675.3852] modem["cdc-wdm0"]: modem state changed, 'enabling' --> 'enabled' (reason: user-requested)
error: no actions specified
ak@U18:~$ mmcli -m 1
error: couldn't find modem at '/org/freedesktop/ModemManager1/Modem/1'
ak@U18:~$ mmcli -m 0
General | dbus path: /org/freedesktop/ModemManager1/Modem/0
| device id: a9a9c67168bd0cbff27762693b6313619d8cccb8
Hardware | manufacturer: Sierra Wireless, Incorporated
| model: EM7455
| revision: SWI9X30C_02.24.05.06 r7040 CARMD-EV-FRMWR2 2017/05/19 06:23:09
| h/w revision: 1.0
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: 359073065280905
System | device: /sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-5
| drivers: qcserial, qmi_wwan
| plugin: Sierra
| primary port: cdc-wdm0
| ports: ttyUSB0 (qcdm), wwp3s0f0u5i8 (net), ttyUSB2 (at),
| cdc-wdm0 (qmi)
Numbers | own: 17863816477
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-pin2 (10), sim-puk (10), sim-puk2 (10)
| state: enabled
| power state: on
| signal quality: 0% (cached)
Modes | supported: allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 3g, 4g; preferred: 3g
| allowed: 3g, 4g; preferred: 4g
| current: allowed: 3g, 4g; preferred: 4g
Bands | supported: utran-1, utran-3, utran-4, utran-5, utran-8, utran-2,
| eutran-1, eutran-2, eutran-3, eutran-4, eutran-5, eutran-7, eutran-8,
| eutran-12, eutran-13, eutran-20, eutran-25, eutran-41
| current: eutran-1, eutran-2, eutran-3, eutran-4, eutran-5, eutran-7,
| eutran-8, eutran-12, eutran-13, eutran-20, eutran-25, eutran-41
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 359073065280905
3GPP EPS | ue mode of operation: csps-2
SIM | dbus path: /org/freedesktop/ModemManager1/SIM/0
