wip_FTPCreateOpts always returns NULL.
I know someone who had the same problem with the 2686 and when he moved to 2687 it worked.
Im using the fastrach FSU2. Should be a Q2687 in there but it still doesnt work.
I was told that regardless of the multitude of upgrade combinations it just works on the 2687 and doesnt on the 2686 we have bought.
Problem is I have a 2687 and it doesnt work so Im pretty lost for option.
Help?
fft
2
You most likely don’t have bought the (paying) “full IP” option, which enables FTP, HTTP, SMTP and POP3. Contact your distributor about this.
awneil
3
Check this with AT+WCFM=5 - see the AT Commands manual for details…
Also, if you use TMT, look for an (undocumented) ERRLOG entry in the Trace…
It really would be a lot more helpful if Wavecom provided proper API return codes to identify this type of problem!
See also: viewtopic.php?f=16&t=2733&p=10094
