Im using the Wavecom Fasttrack M1306 on a couple of computers running Windows XP Pro for a while. On the application there using its important that the maintain online, but this just wont do
Im running in to serious errors lately. The connection keeps getting disconnected, and does not reconnect anymore. Of just doesnt connect at al. Its inevitable that it disconnects sometimes, but it must reconnect then, but it doesnt do that either.
I have the following settings:
OS: Windows XP Pro SP2 fully updated
Modem: Standaard 19200 bps Modem
Dialup nr: 99**1#
Modem init string: at+cgdcont=1,“IP”,“internet” (internet is apn of my provider)
I tried also to reset the modem with at+cfun=1, and then reconnect the dialupconnection in an script, but this doesnt help either. Windows gives ras error 718, of 621, (more frequently 621)
Are there specific settings involved to avoid this?
I`m sorry, i googled my fingers of last weeks, and error 681 stands for anything the modems is erroring the computer cannot understand.
My main question is; are there people here ho also use wavecom devices by dialup networking, with continuous connection without problems ? The modems are installed in Trucks, and move around al day. Does it maybe have anything to do with that ?
cheers,
EDIT:
Nice to mention though is that almost always gets reconnected when i unplug the power from the modem, and replug it again…
De PCs Are builtin PCs onboard of the trucks. A kind of CarPC concept. The modems are atached to them permanently, and must have continuous connection, and thats the problem.
Have you tried the fasttrack modem driver instead of the std. 19k2 driver?
I had some problems connecting to GPRS via the standard drivers, with the fasttrackd drivers everything was working with XP. (but I didn’t get it working on 2k).
BTW, have you done a AT+WGPRS=0,0 before (autoattach GPRS)?
The modem must be attached on gprs. You can have a look enabling a terminal when dialling. AT+CGATT? must reply a +CGATT:1
Well, de connection actually does work some of the time. Doesnt that mean that the GPRS attach works ? I was also adviced by my supplier tot try AT+WGPRS=7,1. (for crossing border areas?) Is that any good?
