Where download the Developer studio 2.2.1 ?
Hi everyone;
I am working with GL6100 modem, I know that the version that supports that modem is the Developer Studio 2.2.1.
Anyone knows Where download that version or maybe other releases diferent than the newest one?
Can you check with Dev Studio version 2.3.2. It seems this version supports GL6100. Below link will help you to install Dev Studio 2.3.2.
http://developer.sierrawireless.com/Resources/Resources/AirPrime/Software/Release_notes/Developer_Studio_2_3_2.aspx#Bugs232
You can go with developer studio light installer with : http://developer.sierrawireless.com/Resources/Resources/AirPrime/Software/Open%20AT%20Application%20Framework.aspx
Rex
I have tested with Developer Studio 2.3.2.
It recognizes GL6100, but will not let me select this when I attempt to compile for this as a target.
It does let me select it as a target to transmit compiled programs to, so I think it might be the case that the modem itself is supported in studio but the compiler does not support the chip inside (WMP100).
This is according to this post: https://forum.sierrawireless.com/t/gl6100-development/7482/1
This then gets us back to the original question of does there exist a download link for Developer Studio 2.2.1?
DS 2.3.2 is actually supporting GL modules.
You need to install one of the 2.3X Open AT Application Framework packages, and from there you’ll be able to create and build projects targeting GL modules.
