Using Starlink with MP70
Hello, my organization is looking at deploying Starlinks for connectivity to our MP70 devices. Does anyone have any experience with doing this or is there a guide to how to build this connection?
Hi @callista
Could you please let me know specifically what kind of connection you want to set up with MP70?
Please refer to AirLink MP Series Software Configuration Guide at the following link to see if it’s helpful for you: https://source.sierrawireless.com/resources/airlink/software_reference_docs/airlink-mp-series---configuration-guide/#sthash.DiUusNc8.dpbs
I am also looking for a configuration setting for the mp70 and a Starlink.
It currently does not stay connected
Hi @rlawrence78,
Could you please let me know the band and carrier used by the Starlink system you are using?
We we using Verizon and a MP70.
I’m having trouble keeping the Starlink connected. It keeps dropping the connection and when it is connected, I have less than one megabyte speed.
When I connect the factory Starlink router, everything works perfectly so I’m guessing there is some sort of a setting or packet loss between the mp70 and the Starlink dish
Hi @rlawrence78,
Please get the log and template log by following the instructions and send them to me so I can further check.
1.The configuration template file is in ACEmanager → Template, provide any name you desire for the Template Name, and then press Download to retrieve the template file.
2.Collect logs procedure:
a. Go AceManager > Admin > Configure Logging
  • Set all log levels to DEFAULT (NOTICE)
  • Set Linux Syslog to DISPLAY
b. Reboot the gateway.
c. Perform your test again.
d. Go Admin → View log → Download Logs.
