Hi, i am trying to upgrade the firmware but could not make, and shows a connection error
“ssh: connect to host 192.168.2.2 port 22: Connection refused”
I restarted, pressed the reset button and i can ping but refuse connections. Could someone help me?
jyijyi
November 20, 2020, 1:22am
2
did you shutdown the firewall of module by
iptables -I INPUT -j ACCEPT
Thanks, i am able to connect now and i did it. But still i am not getting it into studio?
i have closed the firewall of windows.
jyijyi
November 20, 2020, 1:50pm
4
Developer studio is also using ssh connection.
You can also try developer studio in linux pc.
i have downloaded the studio of linux but how to install?
jyijyi
November 20, 2020, 3:33pm
6
Extract it and it should be ready to use
once i double click into “devstudio” it not opening the studio and i have java installed
jyijyi
November 21, 2020, 4:13pm
8
Why did you download the 32 bit one
yes i did install 64 bit but it shows an error. probably visual studio plugin would be a good choise, please let me know, i am stopped here
jyijyi
November 22, 2020, 2:21am
10
Then you can try VS code as developer studio is going to be end of life
i am trying to do so but getting error, the picture attached. it seems that the bug is not fixed yet.
could you please help me to install since i am stopped here, my code and system design are ready to go. It was working before but now the mangoh module is not attaching.
I can provide teamviewer log id and pw to access the same PC that i trying to install.
i am following Install the Legato Plugin for VSCode - Legato Docs
jyijyi
November 24, 2020, 12:02am
12
You can have a look on this one:
Which ubuntu version are you using?
Are you using vmplayer?
Btw, your developer studio should be ok to compile the app.
You don’t really need to connect the module, you can ssh to module or scp the .update file to module for installation.
It is Ubuntu 18.04.3 LTS and not using VMplayer. it is installed in the laptop separate partition. It seems that need to reinstall ubuntu?
jyijyi
November 24, 2020, 3:17pm
14
you can try, but I don’t see problem on ubuntu 18
hi, again the module is connecting to linux machine
it is pinging but not able to login with ssh root@192.168.2.2
as you said "did you shutdown the firewall of module by
iptables -I INPUT -j ACCEPT"
i cannot login to the module, how can i shutdown the firewall. i can shutdown PC firmware
jyijyi
November 28, 2020, 11:32pm
16
Why you can connect before but now cannot?
I dont know actually, suddenly connected before and i did shutdown the firewall.
jyijyi
November 30, 2020, 12:13am
18
Then i don’t know about your pc either, you need to figure out what you had done before.
Definitely this is a pc instability issue
