I am not able to login to my device using ssh
ssh -v -oHostKeyAlgorithms=+ssh-rsa root@192.168.2.2 I have used this command for login.
are you able to log in by tera term in windows?
I haven’t, but i will try and let you know.
Did you capture wireshark and compare with a ok device?
You might also see this:
I have no idea about wireshark but i will try it and I have r17 ig will it still work ?
Wireshark is raw capture to pc, not related to firmware version
Btw, did you also see kernel message in uart2 to see if there is any clue?
I meant the swiflash.bat
Swislflash to restore the default mode only works in r12 or before
How to see kernel message ? I have no idea ![]()
I have wp7611 is downgrade possible for this ?
R17 cannot be downgraded to previous version
Just use tera term to open uart of module
which one should I select ?
and what should i do after selecting
These ports are from usb, not uart
How can I get uart, I am completely new to this sorry.
Of course you need to check schematic of your hardware
will passing at commands do anything ? And other thing that i have keep getting online is ssh service might be in stopped state on the device could that be the case ?
Ok there isn’t uart for the hardware.
No, AT command cannot reset the module
