SL8082T 7.52.2.A5 FW update fails - Card Detect Service
I’m trying to upgrade my SL8082T to 7.52.2.A5 (OpenAT version) using R7.52.2.A5.201411281219.SL808x.exe on Windows 10.
The problem is BinUpdater is failing with response code 5 after running CSwiCardDetectObserver. The error is:
<> System Error - Card Detect Service
fails to initialize carddetect service even after running carddetect msi
I’ve attached the debug log from BinUpdater. My environment is:
Windows Edition: Windows 10 Professional 64 bit
Java Version: JRE 1.8.0_60-b27 32 bit
SL8 Driver Version: 11.5.1005.5
Has anyone come across this before? How can I resolve this issue?
Thanks.
BinUpdater.log (11.3 KB)
If you have any other exe FW file, try to extract the bin updator from that and try to update FW via this updator :wink:
Also try with some other Windows machine…
Alex
I have the same error with two different firmware files:
  • R7.52.0.201404040850.SL808x.exe
  • R7.52.2.A5.201411281219.SL808x exe.exe
Those two firmware utilities both work fine on the same PC when running Windows 7.
So it looks like the BinUpdater utility might not work on Windows 10.
