I have an RV50 used as an sms gateway for a scada pc. I’ve set up several of these before but this particular sim card doesn’t wan’t to play ball. I’ve included logs which probably explain better than I can.
First log is a bootup of the RV50 with my own personal (Three) sim card in it. Works fine.
https://pastebin.com/Q2BUv4DR
Second log is a bootup of the RV50 with this nightmare sim card (also Three, sms only). Does not work fine.
https://pastebin.com/Sb5V9Q2A
Keep in mind, the physical setup never changes, only the sims are swapped. Which is why I don’t really believe the RADIO DETACH errors I’m seeing here.
