RV50 Outbound Trusted IP
Good morning,
I have a technical question about RV50.
From the configuration guide I see that a lot of configuration parameters can be set by AT commands.
My interest is to set from an external electronic board the Outbound Trusted IP’s but in the configuration guide I see only the AT command for the Inbound Trusted IP’s.
Is it possible to set Outbound Trusted IP’s and Enable/Disable of this function by AT command?
Because I want to limit the access from LAN to one external IP in some situations and leave internet open in other situations.
