RV50 No Longer Sending SMS
I have a RV50 that has been operational for years and all of the sudden it has stopped working. Below is the error message from the log when I attempt to send out a text. I don not know exactly what this means. Thank.
Nov 13 23:50:05 err ALEOS_SYSTEM_CSM: Destination message queue /qConG has 5 msgs out of 5 max
Nov 13 23:50:05 err ALEOS_SYSTEM_CSM: Sending notification (MSCIID 10105) to client /qConG failed
Nov 13 23:50:52 err ALEOS_SERVICES_SMSPROC: Destination message queue /qConG has 5 msgs out of 5 max
Nov 13 23:50:52 err ALEOS_SERVICES_SMSPROC: handleSMSSendStatus: Unable to send SMS message to QCON
Hi @richardt,
Welcome to our community!
  1. What ALEOS version and radio module firmware is RV50 running?
  2. How do you send SMS messages? Using AT commands or UI Web ACEmanager?
  3. Which network’s SIM card are you using?
  4. Please share the log file on RV50 with me.
Thank you.
Aleos 4.16.0
Radio firmware 5.05.58.05
Messages are sent using commands (Has been working for years)
Verizon SIM
I can not post the logs publicly because there is sensitive information like IP addresses, but here are some of the log files with the ip addresses removed.
Nov 16 13:24:39 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:25:40 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:26:40 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:27:40 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:27:43 notice ALEOS_LINKMGMT_linkmon: Current: RSSI=-42, RSRQ=-7, RSRP=-71, SINR=26.2
Nov 16 13:28:40 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:29:40 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:30:40 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:31:40 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:32:31 notice ALEOS_CELL_RadioTask: cbkPacketSrvStatus - v4SessionID: v6SessionID: 0 state: 1 (DISCONNECTED) reconfig not required
Nov 16 13:32:31 notice ALEOS_CELL_RadioTask: cbkPacketSrvStatus - ipfamily: 4, call end reason: 1, verbose call end type: 3, verbose call end code: 1034
Nov 16 13:32:31 notice ALEOS_CELL_RadioTask: Radio_state → RADIO_STATE_DISCONNECTED
Nov 16 13:32:31 notice ALEOS_LINKMGMT_linkstatd: wwan0 is now down
Nov 16 13:32:31 notice ALEOS_CELL_RadioTask: APN read from Radio Module: ‘’
Nov 16 13:32:31 notice ALEOS_CELL_RadioTask: OMA DM is supported, no Auto APN lookup of APN is possible
Nov 16 13:32:31 notice ALEOS_CELL_RadioTask: APN set to blank to allow the network to configure it
Nov 16 13:32:31 notice ALEOS_CELL_RadioTask: APN Selection: Primary APN: ‘’ (User Entered)
Nov 16 13:32:31 notice ALEOS_CELL_RadioTask: Using APN from radio module: ‘’
Nov 16 13:32:31 notice ALEOS_LINKMGMT_linkmon: Radio Connection State - Not Connected
Nov 16 13:32:31 notice ALEOS_LINKMGMT_linkmon: New Link Status - Network Link Down
Nov 16 13:32:31 notice ALEOS_CONNECTMGMT_CMAN: scheduleIPV4StatusChange: Restart firewall
Nov 16 13:32:31 notice ALEOS_CELL_RadioTask: Radio_state → RADIO_STATE_DISCONNECTED_WAIT
Nov 16 13:32:31 notice ALEOS_SECURITY_Firewall: Stopping firewall
Nov 16 13:32:31 notice ALEOS_SECURITY_Firewall: Applying IPv4 firewall configuration
Nov 16 13:32:31 notice ALEOS_SECURITY_Firewall: Successfully applied firewall configuration
Nov 16 13:32:31 notice ALEOS_SECURITY_Firewall: Starting firewall
Nov 16 13:32:31 notice ALEOS_SECURITY_Firewall: Initializing firewall tables
Nov 16 13:32:31 notice ALEOS_SECURITY_Firewall: DMZ State: Disabled, DMZ IP: 0.0.0.0
Nov 16 13:32:31 notice ALEOS_SECURITY_Firewall: Inbound port filtering active. Configured to allow only selected ports
Nov 16 13:32:31 notice ALEOS_SECURITY_Firewall: Applying IPv6 firewall configuration
Nov 16 13:32:32 notice ALEOS_SECURITY_Firewall: Successfully applied firewall configuration
Nov 16 13:32:32 notice ALEOS_SECURITY_firewallManager: Firewall completed restart after 892 ms
Nov 16 13:32:32 alert ALEOS_CONNECTMGMT: IPV4 Disconnect Handled
Nov 16 13:32:33 notice ALEOS_CELL_RadioTask: Radio_state → RADIO_STATE_NOTREADY_WAIT
Nov 16 13:32:33 notice ALEOS_CELL_RadioTask: Radio_state → RADIO_STATE_CONNECT
Nov 16 13:32:33 notice ALEOS_CELL_RadioTask: IPPreference : IPv4
Nov 16 13:32:33 debug ALEOS_CELL_RadioTask: iSLQSStartStopDataSession/2975: WDS start interface verbose error: 0
Nov 16 13:32:33 notice ALEOS_CELL_RadioTask: cbkPacketSrvStatus - v4SessionID: v6SessionID: 0 state: 2 (CONNECTED) reconfig not required
Nov 16 13:32:33 notice ALEOS_LINKMGMT_linkstatd: wwan0 is now up
Nov 16 13:32:34 notice ALEOS_CELL_RadioTask: Connected IPv4; IPv4:
Nov 16 13:32:34 err ALEOS_CELL_RadioTask: AL_getDataBearerTechnology Return Code: 1071
Nov 16 13:32:34 notice ALEOS_CELL_RadioTask: Radio_state → RADIO_STATE_DISCOVERY
Nov 16 13:32:34 notice ALEOS_LINKMGMT_linkmon: Radio Connection State - Connected
Nov 16 13:32:35 notice ALEOS_CELL_RadioTask: Radio_state → RADIO_STATE_CONNECTED
Nov 16 13:32:35 notice ALEOS_CONNECTMGMT_CMAN: scheduleIPV4StatusChange: Restart firewall
Nov 16 13:32:35 notice ALEOS_CELL_RadioTask: Value “name” read from XML file using iccid: ‘Unknown’
Nov 16 13:32:35 crit ALEOS_CELL_RadioTask: CellParmRead: Failed to execute CellParm
Nov 16 13:32:35 notice ALEOS_CELL_RadioTask: Operator : Verizon
Nov 16 13:32:35 notice ALEOS_SECURITY_Firewall: Stopping firewall
Nov 16 13:32:35 notice ALEOS_SECURITY_Firewall: Applying IPv4 firewall configuration
Nov 16 13:32:35 notice ALEOS_SECURITY_Firewall: Successfully applied firewall configuration
Nov 16 13:32:35 notice ALEOS_SECURITY_Firewall: Starting firewall
Nov 16 13:32:35 notice ALEOS_SECURITY_Firewall: Initializing firewall tables
Nov 16 13:32:35 notice ALEOS_SECURITY_Firewall: DMZ State: Disabled, DMZ IP: 0.0.0.0
Nov 16 13:32:35 notice ALEOS_SECURITY_Firewall: Inbound port filtering active. Configured to allow only selected ports
Nov 16 13:32:35 notice ALEOS_SECURITY_Firewall: Applying IPv6 firewall configuration
Nov 16 13:32:36 notice ALEOS_SECURITY_firewallManager: Firewall completed restart after 912 ms
Nov 16 13:32:36 notice ALEOS_CONNECTMGMT: *** Network Connection successful. WAN IP [Cellular] :
Nov 16 13:32:36 notice ALEOS_CONNECTMGMT: *** IP UP : wwan0
Nov 16 13:32:36 notice ALEOS_CONNECTMGMT: Setting WWAN MTU size to 1428
Nov 16 13:32:36 notice ALEOS_CONNECTMGMT: GDNS is restarting dnsmasq
Nov 16 13:32:37 notice ALEOS_LAN: MTU Source Auto - Set DHCP option 26 MTU: 1428
Nov 16 13:32:37 err ALEOS_LAN: MTU Source Auto - Ignore Opt 26 MTU size 1500
Nov 16 13:32:38 notice ALEOS_LAN: Starting dnsmasq
Nov 16 13:32:39 notice ALEOS_LINKMGMT_linkmon: New Link Status - Network Ready - Cellular
Nov 16 13:32:39 warning ALEOS_SERIAL_HMC: not in tcp mode current mode 0
Nov 16 13:32:40 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:33:41 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:34:41 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:35:41 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:36:41 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:37:41 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:38:41 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:39:41 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:40:42 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:41:42 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:42:42 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:42:43 notice ALEOS_LINKMGMT_linkmon: Current: RSSI=-42, RSRQ=-7, RSRP=-71, SINR=23.1
Nov 16 13:43:42 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:44:42 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:45:42 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:46:42 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:47:42 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:48:43 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:49:43 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:50:43 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:51:43 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:52:43 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:53:43 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:54:43 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:55:44 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:56:44 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:57:43 notice ALEOS_LINKMGMT_linkmon: Current: RSSI=-42, RSRQ=-7, RSRP=-71, SINR=17.2
Nov 16 13:57:44 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:58:44 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 13:59:44 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:00:44 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:01:44 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:02:44 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:03:45 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:04:45 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:05:45 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:06:05 notice ALEOS_SERVICES_SNTP: Current time: Thu, 16 Nov 2023 14:06:04 UTC SNTP time used to set both system time and HW clock system time to: Thu, 16 Nov 2023 14:06:05 UTC
Nov 16 14:06:45 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:07:45 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:08:45 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:09:45 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:10:46 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:11:46 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:12:43 notice ALEOS_LINKMGMT_linkmon: Current: RSSI=-42, RSRQ=-9, RSRP=-71, SINR=20
Nov 16 14:12:46 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:13:46 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:14:46 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:15:46 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:16:46 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:17:46 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:17:59 notice ALEOS_WEB_ACEmanager: User [user] login successful from IP
Nov 16 14:18:47 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:19:47 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:20:47 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:21:47 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:22:47 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:23:47 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:24:47 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:25:48 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:26:48 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:27:43 notice ALEOS_LINKMGMT_linkmon: Current: RSSI=-42, RSRQ=-6, RSRP=-71, SINR=24.4
Nov 16 14:27:48 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:28:48 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:29:48 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:30:48 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:31:48 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:32:48 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:33:49 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:34:49 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:35:49 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:36:49 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:37:40 notice ALEOS_WEB_ACEmanager: User [user] login successful from IP
Nov 16 14:37:49 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:38:49 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Nov 16 14:39:49 notice ALEOS_CELL_RadioTask: GetFotaState: could not find fota state from command AT.DMREAD=“5/0/3”
Hi @richardt,
From the log you provided, I couldn’t identify any issues related to the inability to send SMS on the RV50.
Therefore, in this case, you should send an email to technical support at support@sierrawireless.com for further assistance.
