Recovery RV50 Unable to install Firmare
Hi guys! I have a RV50 I get into recovery mode, update screen, and upload the firmware (RV50_4.16.0.021.bin), but it gives an error when it starts to install them.
See the log below:
Updating...
Preparing install...
/dev/mmcblk0p2 will be corrupted at index 128, by writting 1024*1024 bytes from /dev/urandom
Kernel is now corrupted
Formatting device...
Partition to format : /dev/mmcblk0p5
Format partitions...
Creating filesystem with 329728 4k blocks and 329824 inodes
Filesystem UUID: 1f114780-c31d-4096-b9f3-87d775ff0f47
Superblock backups stored on blocks:
	32768, 98304, 163840, 229376, 294912
Allocating group tables:  0/11     done
Writing inode tables:  0/11     done
Creating journal (8192 blocks): done
Writing superblocks and filesystem accounting information:  0/11     done
tune2fs 1.43-WIP (23-Nov-2014)
Partition to format : /dev/mmcblk0p6
Creating filesystem with 253952 1k blocks and 63488 inodes
Filesystem UUID: 240f027f-1bbb-4a40-baeb-632eea8094b8
	8193, 24577, 40961, 57345, 73729, 204801, 221185
Allocating group tables:  0/31     done
Writing inode tables:  0/31     done
Creating journal (4096 blocks): done
Writing superblocks and filesystem accounting information:  0/31     done
Mounting HDA1...
Installing...
> [swpreinstaller] Installation started
> [swpreinstaller] Open /www/upload/RV50_4.16.0.021.bin
   [AleosUpdater::open] check file
   [AleosUpdater::open] init cert verification
   [AleosUpdater::open] Check failed: Could not parse directory: Cannot open dir /usr/local/etc/crl
   [AleosUpdater::open] verify certificate /usr/local/etc/crt/SWI-ESBU-Root-01.crt
populateLedFileStreams: Complete
   [AleosUpdater::open] verify signature /usr/local/etc/crt/SWI-ESBU-Root-01.crt
   [AleosUpdater::open] verification done /usr/local/etc/crt/SWI-ESBU-Root-01.crt
[AleosUpdater::open] Extracting tar file failed (No space left on device) (13)
> [swpreinstaller] Error 13 : Opening /www/upload/RV50_4.16.0.021.bin failed
> [swpreinstaller] Installation failed
Installation failed. Please, retry.
I would like to check if there is any recovery mode yet, or if the router has become scrap.
Thank you!
Hi @Cleber,
Welcome to our community!
Can you currently access the RV50 through the ACEManager web UI, or is the device stuck in recovery mode?
If you can access the ACEManager web UI, please refer to the following solution:
"This is an error that typically occurs when the customer has installed the maximum allowed Radio Module Firmware.
To remove an unnecessary installation they will need to connect to AceManager and navigate to Admin>Radio Module Firmware and click remove on the firmware they are needing cleared"
Hi @jerdung .
Thank you
I have been accessing the modem only in recovery mode and it’s unable to access the ACEManager web UI, because in normal mode… it was rebooting…
Thank you.
