Problem installing firmware and not able to find APN.
I have reinstalled the Generic for a T-mobile Static SIM firmware several times and using ALEOS version 4.18.1. I still can’t get on the network with a few RV50X’s.
I get the following notification…
Hi @jbrylawski,
Could you please answer the questions below to narrow down the issue?
As far as I know, T-Mobile has merged with Sprint, so could you please try installing the RV50X Radio Module Firmware for Sprint from the following link: source.sierrawireless.com/resources/airlink/software_downloads/rv50/rv50x-firmware-list/ and check whether this issue occurs?
To investigate this issue, please get the log and template log by the instructions and send me:
- The configuration template file is in ACEmanager → Template, provide any name you desire for the Template Name, and then press Download to retrieve the template file.
- Collect logs procedure:
a. Go AceManager > Admin > Configure Logging
Set Linux Syslog to DISPLAY
b. Reboot the gateway.
c. Perform your test again.
d. Go Admin → View log → Download Logs
Hi Jerdung,
I downloaded the Sprint firmware and sent it to the RV50X, but I can not activate it. See below…
I do not know why it shows…
*/!\ Installed firmware doesn’t match any firmware from the storage. /!*
SIM Based Radio Module image switching has been disabled.
Attached are:
Template - Pennoni_RV50X
Log - filteredlogs
Please let me know if this is what you need.
Thank you,
Jim
(Attachment Pennoni_RV50X.xml is missing)
(attachments)
filteredlogs.txt (1.15 MB)
