Due to USIM-related issues, i will need to remove the mangoh yellow that was registered with Octave.
Do you happen to know how?
Do I have to withdraw from the Ocatave account?
Contacting you in PM to understand better your need.
Your mangOH yellow works with any SIM.
can you explain about PM?? i don’t know PM…
Hi Andy,
PM means “private message”. Please check your messages.
Hi andykim
I haven’t tried this yet but the following should work so long as !CUSTOM=”UIMAUTOSWITCH” is not set
If you would like to switch to the external SIM instead of the Octave connected internal SIM you could try reading current setting with
AT!UIMS?
Parameters:
(SIM interface):
• 0=UIM1—External UIM interface #1
• 1=UIM2— External UIM interface #2 or eSIM (embedded SIM). Depending on the
module, the interface may be exposed to an external SIM
Change to external SIM
AT!UIMS=0
More details are in the AT command manual
Cheers
John
