MangOH Yellow OOB can’t connect to octave using GettingStartedGuide
I’m evaluating mangOH yellow with which I managed to follow the Getting Started Guide to connect the device and interact directly with it (step 4) without any problem.
When I tried to connect to Octave to obtain sensor data (step 5.2) is when I started having problems as the device were never detected by Octave (device were not in Las Vegas mode).
If I power cycle the device, the Network LED turns green as it starts, then after a moment, the Nwk yellow LED becomes ON (The green one remains on) as it is supposed to happen… right?
After this I start digging on what might cause this for which I:
  • Attached the antenna to the connector labeled as ‘main’, same result.
  • Followed the guides indicating how to update the firmware (yellow_wp77xx_0.5.0-octave.spk) after which I the device did not connect to Octave, even when the procedure indicated success.
  • Investigate on the API to know what happen to the device (where is the list of commands that can be used in a ssh session with the device, so far I only use what I saw people using in the forums?)
  • Using ‘cm radio’ after a reset several times I notice that the radio was not being able to register to the LTE-M network, I notice 3 types of state:
root@swi-mdm9x28-wp:~# cm radio
Power: ON
Current Network Operator:
Current RAT: Module not registered on network, RAT not available
Status: Not registered and not currently searching for new operator (LE_MRC_REG_NONE)
Signal: No signal strength (0)
PS: Packet Switched Not registered (LE_MRC_REG_NONE)
Power: ON
Current Network Operator: Sierra Wireless
Status: Not registered but currently searching for a new operator (LE_MRC_REG_SEARCHING)
Signal: Very strong signal strength (5)
Power: ON
Status: Registration was denied, usually because of invalid access credentials (LE_MRC_REG_DENIED)
After this, I saw people communicating directly to the modem using AT commands, for which ‘microcom’ is used: ‘microcom -E /dev/ttyAT’
however, if I use this I get the following message:
root@swi-mdm9x28-wp:~# microcom -E /dev/ttyAT
microcom: invalid number ‘/dev/ttyAT’
I have been reading all day about how to know what my problem is to get the out of the box demo to work without success and at this point I think I need a bit of help.
Additional info that might help:
root@swi-mdm9x28-wp:~# cm info
Device: WP7702
IMEI: 352653090210394
IMEISV: 4
FSN: 4L936370340610
Firmware Version: SWI9X06Y_02.32.02.00 c2e98c jenkins 2019/08/30 07:28:21
Bootloader Version: SWI9X06Y_02.32.02.00 c2e98c jenkins 2019/08/30 07:28:21
MCU Version: 002.013
PRI Part Number (PN): 9909138
PRI Revision: 001.001
Carrier PRI Name: SIERRA
Carrier PRI Revision: 001.027_000
SKU: 1104405
Last Reset Cause: Power Down
Resets Count: Expected: 27 Unexpected: 0
root@swi-mdm9x28-wp:~# cm data
Index: 1
APN: iot.swir
PDP Type: IPV4V6
Connected: no
root@swi-mdm9x28-wp:~# cm sim info
Type: EMBEDDED
ICCID: 89332401000010872485
Home Network Operator: Sierra Wireless
EID: 89033240817620069918070003392558
IMSI: 234507089996147
Phone Number:
I’m located in Mexico, Baja California, can the device be used in here?
Please, let me know if more information is needed to know what is happening or what can I try to get the device to work.
Any help is appreciated!
UPDATE: I got the same result using: https://downloads.sierrawireless.com/mangOH/exe/yellow_wp77xx_0.5.0-octave.exe
Log of radio state below, output of the .exe file at the end.
Power: ON
Power: ON
Power: ON
Signal: Strong signal strength (4)
Output of yellow_wp77xx_0.5.0-octave.exe
FDT version: 1.0.1902.1
Awaiting adapter …
Setting images preference …
Resetting …
Awaiting download port …
Switching to streaming mode …
Downloading images …
Writing image /
Flashing image \
Awaiting adapter …
Checking update status …
Enabling selective suspend …
Firmware image download succeeded.
Final Firmware update succeeded.
    Current:
            Firmware:
                    ImageId: 001.027_000
                    BuildId: 02.32.02.00_SIERRA
            Configuration:
Final images information:
    Current:
            Firmware:
            Configuration:
OEM PRI: 9909138 001.001
Total time elapsed: 125266 ms.
Time to switch to boot mode: 31516 ms.
Images downloaded:
    Image ID: 001.027_000
    Build ID: 02.32.02.00_SIERRA
            write time: 22297 ms
            additional flash time: 23063 ms
Time to reset to application mode: 44766 ms.
Press Enter to continue …
UPDATE:
I tried cm radio rat GSM with which I got the same result.
I tried cm radio rat GSM followed by legato restart and got the same result…
Hi Luis, I am fixing the activation issue on your Yellow currently.
the yellow_1 is activated now.
Can you power it on again and see if it connects?
I can connect with mangoh_y_01 now, thanks!
Hi Luis, good to know. I did the same fix on the mangoh_y_02.
Hello dla,
it seems I have the same problem as reported by Luis.
Could you please verify if it is possible to activate also my mangOH yellow?
I am based in Italy and below you can find my yellow relevant parameters:
IMEI:  352653090193020
ICCID: 89332401000010744585
FSN:4L931389111610
Please to let me know in case you need further info.
Many thanks for your help!
Best regards,
Davide
Hi, I am looking at it.
Will keep you informed
Can you tell me which company you have registered your mangOH in?
I have activated the manGOH, I want to check it connects.
Is it possible to provide those details by private message?
Many thanks,
Davide
Hello dla,
IMEI:                          352653090192501
FSN:                           4L931389100210
Best regards,
Rachid Kherrazi
I believe I have the same issue and posted in Octave.
