I tried to register my FSN/IMEI in Octave and it keeps going back to step 3 asking me for IMEI/FSN anthough they are both listed correctly. Also “cm radio” says module not registered on network.
Power: ON
Current Network Operator:
Current RAT: Module not registered on network, RAT not available
Status: Registration was denied, usually because of invalid access credentials (LE_MRC_REG_DENIED)
Signal: No signal strength (0)
PS: Packet Switched Not registered (LE_MRC_REG_NONE)
I was able to get to the confirmation step with the IMEI/FSN you provided.
I did not create the device.
Could you check your browser against the following?
The Octave Dashboard’s web application leverages the latest browser technologies to provide an up-to-date view of connected assets. It currently supports the following browsers:
Firefox (version 73 and above)
Chrome (version 80 and above)
Safari (version 13 and above)
Microsoft Edge (version 80 and above)
I’m using Chrome on Ubuntu: Version 88.0.4324.150 (Official Build) (64-bit)
I get all the way to the confirmation step as well and when I click confirm it just takes me back to Step 3 with no error message of any kind. Stuck in an infinite loop… Keep clicking though and it always takes me back to Step 3.
Edit: I also tested on a Mac running Chrome and same issue.
We have changed the process in which the mangOH Yellow is activated.
The new process is to make the user supply a credit card before activation. The credit card will not be charged for 3 months.
The issue you are seeing is a result of the backend process being updated while the User Interface push was delayed. The User Interface update should be pushed today. The User Interface update will allow you to complete the activation process. You will have to enter a credit card to complete the process.
We will post an update when the User Interface push is completed so you can successfully complete the device activation
