New Q24 plus module
Hi, all,
I just received the new Q24 plus eval module from the local vendor. I found all the AT# commands are disabled.
When the following AT commands are sent,
AT+WCFM=2,
it returns +WCFM: 0006,0
ATi3
it returns 657-09gg.q24PL001 1954500 102706 18:44
AT+WCFM=5
it returns +WCFM:00000000
I read the post of wavecom.com/modules/movie/sc … ommand+set
, seems like the module does not come with the IP stack. Am I right?
I used Q2406B before, and it is working fine. AT#APNSERV, AT#UDPPORT etc. are the common commands needs to use.
Is the new Q24 series still supporting AT# command? What do I need to do to make it work?
Please advise.
Wanchope
The Vendor should be able to answer that?
Hi !
read this post : wavecom.com/modules/movie/sc … php?t=1500
Firmware 6.57 cannot use eDLib / eDSoft, but has the WIP internet plugin. The command related to WIP are (as far as i know) AT+WIP… (and not AT# anymore)
Hope it helps
Thanks for your quick reply, man.
May I know where I can find the WIP command set.
I do not want to rely on the local rep as they are not so technical.
so easy to find… :smiley:
http://www.google.com/search?num=20&h&q=wipsoft+filetype%3Apdf&lr=
But strange how there’s no hits on the Wavecom site… :open_mouth:
Thanks, Wallace.
How to confirm whether the Wipsoft already built in?
Any AT command to do so?
My AT+WOPEN=2 response is
+WOPEN:2,“AT v03.12”
Any hint?
regards
Wanchope
As i told you in post wavecom.com/modules/movie/sc … php?t=1500, if wopen=2 answers +WOPEN:2,“AT v03.12”, it means that there is no application loaded in the module.
The format of +WOPEN:2 answer is :
+WOPEN:2,“Open AT compatible version with module”,“Open AT version of the loaded application”
So if there was an application in your module, you’d have something like :
+WOPEN:2,“AT v03.12”,“AT v03.12”
See pdf document : AT Commands Interface Guide (Specific AT commands section)
