I have a Q24PL001 module and when I give any AT# commands I get ERROR.
Does anyone know what could be causing this?
How do I verify that my module has the TCP/IP plugin?
AT+WOPEN=1 gives OK status.
Any help will be appreciated.
AT# was used with the eDSoft TCP/IP-stack.
For Q24PL there is the Wavecom WIP TCP/IP-stack which has a different set of commands.
If WIP is installed, you can check version with AT+WIPCFG=3
Thanks for the clarification.
Does this mean the TCP/IP stack from eDsoft is no longer available?
Where would I find documentation of AT commands that I can use with WIP Stack?
Yes
From the same place that you obtained the WIP Stack?!
