As most of people here is knowing the edlib/ebsoft is to be replaced by Wavecom “WIPLib/WIPSoft” solution.
I had got the WIPSoft (AT+WIP) beta version to testa few days before.
Though it is stated as “beta” version the WIPSoft shows serious problems. That make previous edSoft users very uncomfortable, espically they are requested for the migration in this year…
I had not tried all features but I list out my findings here :
[i]1. AT+IPR=xxx to change baud rate, the “OK” will come out in new baud rate
AT+ADC command the second value is very high (65523)
After starting GPRS bearer (AT+WIP=4,6,0), then make voice call, then ATH can hang up call but not show “OK”
TCP data “Umap” mode (AT+WIPDATA=2,x,0,y) does not work (show ERROR) !!!
In continuous mode, if local side to send ETX character will close socket , but com port will NOT back to command mode automatically, Only after pressing “+++” will see “+WIPPEERCLOSE: 2,1” message
Even see “+WIPPEERCLOSE” message one has to enter “AT+WIPCLOSE” to close socket.
Opening continuous mode TCP data , the “CONNECT” will not appear on new line
If TCP continuous mode is successful, and after some data transfer, pressing “+++” back to command mode will reveive a lot of unsolicited codes +WIPDATA…
For TCP client opening (+WIPCREATE=2,1,xxx) if first attempt is fail will get CME ERROR: 834,
but retry will ALWAYS get error +CME ERROR: 831 +CME ERROR: 800 (even sure the TCP peer is valid), need AT+CFUN=1 -
DLE/ETX pairing in continuous mode cannot be disabled !?)[/i]
