In Dec 2006 I have tried the beta version of wipSoft for Q24xx series
http://www.wavecom.com/modules/movie/scenes/forums/viewtopic.php?t=846
At the end of Jan 07 version 2.01 (assumed formal release) is available. Yet I still feel it is far from acceptable…
Some unsolved old issues :
4. TCP data “Umap” mode (AT+WIPDATA=2,x,0,y) does not work (show ERROR) !!!
Now NO MORE UNMAP MODE data transfer mentioned in new manual! Must use continuous mode
5. In continuous mode, if local side to send ETX character will close socket , but com port will NOT back to command mode automatically, Only after pressing “+++” will see “+WIPPEERCLOSE: 2,1” message
Same. Wavecom assume this is normal behaviour
7. Opening continuous mode TCP data , the “CONNECT” will not appear on new line
Same
8. If TCP continuous mode is successful, and after some data transfer, pressing “+++” back to command mode will reveive a lot of unsolicited codes +WIPDATA…
9. For TCP client opening (AT+WIPCREATE=2,1,xxx) if first attempt is fail will get CME ERROR: 834, but retry will ALWAYS get error …
I got the answer now ! For a chosen index (‘1’ in the above example) if the channel creation is fail you CANNOT use it again (unless reset module)!
You need to use other index (e.g. AT+WIPCREATE=2,2,xxx…)
- DLE/ETX pairing in continuous mode cannot be disabled !?)
Same
And I see more :
In continuous mode, if you enter (control-C) first to close socket, then “+++” back to command mode, then you can never back data mode even new TCP socket is connected , need restart
For FTP, the first time getting file (using AT+wipfile…) is successful, but you cannot repeat this again ! Must need to reset
I don’t know if other fans here have tried the wipSoft or not. But I believe it is still a disaster for old AT# users to migrate. Not only bugs but some “behaviours” of the program makes some old applications unusable.
As stated by Wavecom wipLib is in-house developed, why they cannot build a better wipSoft based on her own Lib ?? And don’t forget SMTP/POP3 feature is not ready at this moment.
My suggestion to coming wipLib users : if you get any ERROR when using any AT+WIPxxx command, better restart your module.
