I am using an RV50X with AT&T SIM as Primary SIM, and Verizon SIM as secondary SIM
Reading the manual, I don’t quite understand how to properly set the Network watchdog, Cellular watchdog, and “Active SIM based firmware switching” features with my current setup.
End goal is to have the ATT SIM as being active as much as possible, and Verizon SIM to be used only when the ATT connection is not working.
To begin with, should I enable “Active Sim based firmware switching” since I have an ATT and a Verizon SIM in the device? The device seems to be able to use either SIM while using an ATT radio module firmware, so I’m not sure when this setting should be enabled.
I currently have Automatic SIM switching settings as follows:
Is this improper? Manual seems to say “Scan timeout” should be “0” if i’m using active sim based firmware switching
what throws me off is that the manual ALSO says that Scan Timeout should NOT be zero if i want automatic sim swiching to occur. Which I do.
