I have LX60 and RV55, both units do not attach to the network.
They do not send RACH request or any comms with the network for both LTE-M and NB-IoT signals.
The Airlink GUI shows that the UE can see the network but RF signal seems low. (see attached captures)
I confirmed that the RF signal is not low because this is a lab environment.
Could you please take a look at the below question/concern and share your answers?
Please make sure that antennas are attached to the routers. Two antennas are required when connecting to an LTE network.
Which ALEOS version and Radio Module Firmware are LX60 and RV55 running? If they are not the latest versions, please refer to the following link to obtain the latest ALEOS version and Radio Module Firmware, and then recheck whether the problem is resolved.
I tried all your suggestions with no success, see details below.
I confirmed that functional antennas are been used for testing. LX60 and Rv55 use only one antenna.
Current ALEOS & Radio Module Firmware
LX60: ALEOS: LX_4.13.0.17
Radio Firmware: WP7702_02.16.06.00_GENERIC_001.028_004
RV55: ALEOS: RV_4.13.0.17
Upgrades to latest versions:
LX60: ALEOS: LX_4.16.0.21
Radio Firmware: WP7702_02.36.06.00_GENERIC_001
RV55: ALEOS: RV55_4.17.0.012 (Upgrade failed; Certificate verification failed: Unable to get a local issuer certificate)
Radio Firmware: WP7702_02.36.08.09_GENERIC_001
SIM Carrier: Generic SIM on a private LTE network.
Please try using the carrier’s SIM on a real network to see if the devices can connect to the network.
→ In order to narrow down the issue from simulator network, we need to recheck on the real network first, so please try to use the SIM from real network at your location to recheck the issue.
