Model: LX40 Verizon Wifi. Firmware: ALEOS 4.16.0.021, RAdio module WP7601 firmware 2.37.06.00.
It was working correctly until the Verizon plan was changed to a static IP plan. Now the Signal, Activity and Power lights are solid green and the Network light is blinking red. There is no network connection.
Solved: The APN was incorrect: it was set to VZWINTERNET, manually updated to we01.VZWSTATIC
WAN/Cellular → Cellular → General → Set Override APN to we01.VZWSTATIC and then reboot.
Hi @adolan-caret,
Welcome to our community!
This issue has been discussed extensively in many similar topics with solutions as you have mentioned: GX440 and change to Verizon static/public IP
In the future, if you encounter similar issues, you can save time by searching the forum first.
