Static Route on Cell Private APN
I am using an LX40 and would like to set up static route on the cell side. I see where to do that on the lan side. I would like to set up static routes on cell side just like setting up for vlan. Is that possible?
Hi @dgary ,
Welcome you to our community!
About the routing on the cellular side, You can refer to Section 4 - WAN/Cellular Configuration on page 107 in the link below:
https://source.sierrawireless.com/resources/airlink/software_reference_docs/airlink-lx40---configuration-guide/#sthash.kNwhCooF.dpbs
Morning
The problem is when using cell the gateway field is not available. Other than that this would work for me. Any way to fix / deal with that?
Hi @dgary ,
I checked on my LX40 with ALEOS 4.16 and I didn’t observe the your issue. Please refer to the screenshot I have attached below:
Please upgrade to ALEOS 4.16 following the link below, then check again:
https://source.sierrawireless.com/resources/airlink/software_downloads/lx/lx-firmware-list/#sthash.ZAv1asjv.dpbs
Do the issue still happens in this case?
Morning
I have downloaded 4.16 and started installing it to the LX40. It has got past the 1. Initialization, 2. Uploading, and is currently on 3. Applying and has been that way for 2 hours. Is it supposed to take that long?
Hi @dgary ,
According to your description, Are you stuck at step 3 as shown below ?
If yes, please select the firmware radio file and upload it to continue the upgrade process.
If not, please describe clearly your issue so I can help you further.
The device stayed at step three, however after three hours I powered it down and rebooted it. It came up and ran. The update worked and the device is at 4.16.
Thanks for following up.
