Is it possible to use Windows 10 VPN Client (or equivalent) to connect over VPN to a remotely deployed LX40 (acting as VPN Server) such that i can remotely access a LAN device on the LX40 from my office PC? If so, any articles or advice would be greatly appreciated!!!
Hi tclark,
There should be a VPN server between your PC and LX40. Both your PC and LX40 should connect to the VPN server as client and you need to make sure client-to-client connections in the VPN server are enabled.
There is a topic about VPN configuration. You can refer here:
So it is not possible to have the LX40 be the VPN Server and allow a client connection to it?
I am not sure how to solve my problem.
I am trying to access a BACnet device connected to a remote offsite LX40 via my office workstation/software.
Hi tclark,
You should have an OpenVPN server between LX40 and your remote PC. LX40 cannot act as server in the picture above.
