Discovered in log of my LX-60s “alert ALEOS_ADMIN_logSysInfo: SIM 1: Not Present” when investigating a complaint of intermittent connectivity. Surveyed my other devices and found this in their logs as well, just not as much.
Can anyone comment, have you experienced this? What steps might solve or improve it?
Hi Ken, can you try these following steps
- Reseat the SIM card.
- Inspect the SIM for damage.
- Update to the latest firmware.
- Test with another SIM card.
- Check for poor signal areas.
I hope this will work for you and resolve your issues also, if still facing same problem then it is better to connect with support team….…
Actions tried today:
- Replaced Regular multi-sized SIM with Single size Rugged SIM
- Inspection of the original SIM (about 3 years old) found no damage or visible contact corrosion.
- The current firmware is 4.16, will leave for now so as not to change too many things at once.
- While there are many dead spots in Saskatchewan, there are none where loss of service was complained of.
Plan: Recheck logs in 10 and 30 days. Gather crew feedback if improved or the same.
Screenshot of filtered log. More to follow. I want to wait at least 10 days before I check the log again.
