I have a GX450 ALEOS or 4.8.1 with an additional router on the LAN side for access to an additional subnet 192.168.51.0/24.
My LAN port is a static configuration of 192.168.58.133/24
I added under the LAN tab “Host Port Routing” as per manual and rebooted.
Host Network 2 192.168.51.0
Host Network subnet Mask 2 255.255.255.0
Host network 2 route Gateway
Host Network 2 Gateway 192.168.58.254
The 192.168.58.254 is the additional router’s port address on the same subnet of the GX450 LAN port subnet 192.168.58.0/24. It has another port for the 192.168.51.0/24.
I can ping 192.168.51.4 from the Subnet 192.168.58.0/24 from a PC, but from GX450 I cannot so I cannot connect to the GX450 from the 192.168.51.0/24 subnet. The GX450 is not sending the packet out the LAN port when I try and ping from the GX450
Is there any else that needs to be done for LAN side routing from the GX450 for subnet outside of it’s local subnet?
