I have inserted airtel sim and wanted to check wherether I am able to connect to internet or not. But when I tried using AT commands it showing, sim card not inserted.
Not sure if hardware problem
What is at!uims?
How about other sim card
I tried now I am able to route into my modem FX30, but its showing
connected No its showing
Is the apn correct?
I can see it shows “connected through rmnet0”
yes its correct but not sure why is it showing connected through rmnet
That means data connected
ok so it means its connected
But im not able to ping, when i use ping command its showing network is unreachable.
What is "cm data"now
Does your sim card work?
Have you monitored +cgreg notification?
If you dial up with AT command port on pc, does it work?
AT cammand were working fine
Yes it was working i tried by using that command
You mean your pc can dial up via atd*99***1# command?
havent tried…will try
Are we using at command with mobile number?
You meam at+cnum command?
