I am trying to bring up an FX30 1105031 with an EIOTclub SIM (triple play = AT&T, T-Mobile, or Verizon) as a USB modem on a Windows 10 desktop. I am using Tera Term to connect to the AT COM port. I had to set APN to “mobile” to get a response to AT!GSTATUS? (it gave ERROR with the default) and get this:
AT+CGDCONT?
+CGDCONT: 1,“IPV4V6”,“mobile”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
AT!GSTATUS?
!GSTATUS:
Current Time: 290 Temperature: 35
Reset Counter: 2 Mode: ONLINE
System mode: LTE PS state: Not attached
IMS reg state: UNKNOWN IMS mode: Not Support
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
LTE band: No band LTE bw: Unknown
LTE Rx chan: — LTE Tx chan: —
LTE CA state: ACTIVE LTE Scell band:No band
LTE Scell bw:1.4 MHz LTE Scell chan: 3
EMM state: Deregistered Attach Needed
RRC state: RRC Idle
PCC RxM RSSI: 0 RSRP (dBm): 0
PCC RxD RSSI: 0 RSRP (dBm): 0
SCC RxM RSSI: 0 RSRP (dBm): 0
SCC RxD RSSI: 0 RSRP (dBm): 0
Tx Power: – TAC: BE68 (48744)
RSRQ (dB): -3181 Cell ID: 00000001 (1)
SINR (dB): 0
Strangely, the SIM ICCID does not match the SIM card I bought, or the Sierra Wireless SIM card which came installed in the FX30, regardless of which one is installed. Does this mean the FX30 is not seeing the installed SIM or is there a setting I can change?
at!iccid?
!ICCID: 89332500000078035942
Thanks for any help!
