How to Configure FX30 to work with a sim card
hi, I’m new to FX30 and have no ideas on how is the process
I inserted a sim card and configured the APN but still i cannot get it work
i will use the Modem for a simple connection , have one Kiosk that i need to connect it to using USB or Ethernet
ATi
Model: FX30(WP7607-1)
Revision: SWI9X07Y_02.18.05.00 000000 jenkins 2018/07/19 17:40:21
IMEI: 352650100107933
IMEI SV: 5
FSN: V2920200511210
+GCAP: +CGSM
at!gstatus?
!GSTATUS:
Current Time: 1941 Temperature: 29
Reset Counter: 1 Mode: ONLINE
LTE band: B3 LTE bw: 10 MHz
LTE Rx chan: 1450 LTE Tx chan: 19450
LTE CA state: INACTIVE
RRC state: RRC Idle
IMS reg state: No Srv
PCC RxM RSSI: -72 RSRP (dBm): -99
PCC RxD RSSI: -96 RSRP (dBm): -135
Tx Power: 0 TAC: 01FD (509)
RSRQ (dB): -10 Cell ID: 00A54507 (10831111)
SINR (dB): 12.2
You can see here to share cellular data to ethernet client
For sharing cellular data to USB ECM interface, you can see here:
(as your FX30 is using WP76 module, you need to change the “usb0” to “ecm0” and “rmnet0” to “rmnet0_data0” inside those commands)
