FX30 - Unable to Connect to Network via SIM Card
Hello, I am trying to use the FX30 as a router, but I am unable to establish a network connection through the SIM card.
I am sharing all the relevant information below:
root@fx30:~# cm info
Device: FX30(WP7702)
IMEI: 354723090962829
IMEISV: 8
FSN: AT327275040510
Firmware Version: SWI9X06Y_02.36.08.09 c094f4 jenkins 2022/06/24 03:14:28
Bootloader Version: SWI9X06Y_02.36.08.09 c094f4 jenkins 2022/06/24 03:14:28
MCU Version: 002.015
PRI Part Number (PN): 9910239
PRI Revision: 001.002
Carrier PRI Name: GENERIC
Carrier PRI Revision: 001.079_000
SKU: 1104770
Last Reset Cause: Power Down
Resets Count: Expected: 7 Unexpected: 0
FX30 Version: R15.1.0.004
root@fx30:~# cm data
Index: 1
APN: em
PDP Type: IPV4V6
Connected: no
root@fx30:~# cm radio
Power: ON
Current Network Operator:
Current RAT: Module not registered on network, RAT not available
Status: Not registered and not currently searching for new operator (LE_MRC_REG_NONE)
Signal: No signal strength (0)
PS: Packet Switched Not registered (LE_MRC_REG_NONE)
root@fx30:~# cm sim
SIM card is inserted and unlocked (LE_SIM_READY).
root@fx30:~# cm sim info
Type: EMBEDDED
ICCID: 89332500000078035652
Home Network Operator: Sierra Wireless
EID:
IMSI: 234500082703517
root@fx30:~# cm sim mode
SIM selection mode: AUTO
If you need any additional information, I will provide it as soon as possible.
Any help or guidance would be greatly appreciated. Thank you!
“cm sim info” shows it is not using SIM slot !
You can double check by AT!UIMS command
Thank you very much for the response.
Indeed, when executing the command AT!UIMS?, it originally returned a value of 3.
I changed this to AT!UIMS=1, and after that, the command cm sim info returns the following:
Type: EXTERNAL_SLOT_1
ICCID: 89332401000030958892
EID:
IMSI: 208240005573967
Phone Number:
However, I am still unable to establish a connection.
I have also executed the following commands in case this information is useful:
AT+CFUN?
+CFUN: 1
AT+CREG?
+CREG: 0,2
AT+COPS?
+COPS: 0
AT!GSTATUS?
!GSTATUS:
Current Time: 200 Temperature: 32
Reset Counter: 3 Mode: ONLINE
System mode: LTE PS state: Not attached
IMS reg state: UNKNOWN IMS mode: Not Support
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
LTE band: No band LTE bw: Unknown
LTE Rx chan: 1 LTE Tx chan: —
LTE CA state: ACTIVE LTE Scell band: No band
LTE Scell bw: Unknown LTE Scell chan: 0
EMM state: Deregistered Attach Needed
RRC state: RRC Idle
PCC RxM RSSI: 0 RSRP (dBm): 0
PCC RxD RSSI: 0 RSRP (dBm): 0
SCC RxM RSSI: 0 RSRP (dBm): 0
SCC RxD RSSI: 0 RSRP (dBm): 0
Tx Power: – TAC: 0000 (0)
RSRQ (dB): 0 Cell ID: 00000000 (0)
SINR (dB): 0
AT+CGDCONT?
+CGDCONT: 1,“IPV4V6”,“em”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IPV4V6”,“em”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
Thanks in advance!
How about using at!uims=0
With AT!UIMS=0, the behavior remains the same.
EID:
IMSI: 234502100284165
Phone Number:
Index: 1
APN: em
PDP Type: IPV4V6
Connected: no
root@fx30:~# cm data connect
Setting up profile 1
Connecting … ok
No interface, cannot proceed.
What kind of sim card are you using?
What network are you trying to connect? gsm? Cat-m? Nbiot?
We are using a card provided by Sierra Wireless, which in a previous FX30 model (prior to the current one) offers a connection without any issues.
In the labeling, the difference I see between both is that the FX30 that works is labeled as the FX30 Generic, LTE CAT 1 EMEA model, while the one that doesn’t work is labeled as the FX30 NB IoT Wireless Gateway model.
Regarding the network I am trying to connect to, it is currently configured as LTE.
root@fx30:~# cm radio getRAT
Prefered RATs : LTE
But previously it was configured as auto and changed it while looking for solutions
I have managed to establish a connection with one of the SIM cards that is not from Sierra Wireless; it is a SIM from Home Network Operator: EMnify, for which I set the APN as em using cm data apn em’. However, with the SIM card provided by Sierra Wireless, I can’t establish this connection, as I can’t find what should be entered in the APN field in this case.
I saw you are using generic pri , but not sierra pri …
https://source.sierrawireless.com/resources/airlink/software_downloads/fx30-firmware/fx30-firmware-catm/
