We are using Sierra FX30S 3G for weather station data transmission. Mostly 3G network is used.
Following problem has been observed several times:
- mobile network registration is lost (no additional information about reasons, too long time before somebody gets to place to get log information)
- attempt to search for mobile network after that lasts forever (days and more)
- when somebody gets to place and connects through USB:
– response to cm radio is:
Power: ON
Current Network Operator:
Current RAT: UMTS network (LE_MRC_RAT_UMTS)
Status: Not registered but currently searching for a new operator (LE_MRC_REG_SEARCHING)
Signal: Very strong signal strength (5)
PS: Packet Switched Not registered (LE_MRC_REG_NONE)
– attempt to turn radio of and after that on does not seem to help
cm radio off
cm radio on
– soft reboot (by entering reboot command restores normal functionality
System:
- custom FW17 build (similar problems are observed also with FW14 (original binary from Sierra Wireless) but I have not have a possibility to study them): small changes like several not normally included packages added (esim. sftp-server that was discussed here earlier separately)
- custom Legato 18.06.5 build (some parts unnecessary for our use removed, some our applications added, for example to keep data connection up)
- data sending is done by legacy program wrapped into Legato application (to avoid locking it to specific system type)
Related information from log (unrelated parts removed from logread output) when commands cm radio off and cm radio on were entered:
Feb 7 14:53:03 fx30s user.err Legato: =ERR= | modemDaemon[835]/modemDaemon T=main | le_sms.c CloseSessionEventHandler() 2311 | SessionRef (0xb704f084) has been closed
Feb 7 14:54:23 fx30s user.err Legato: =ERR= | modemDaemon[835]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 796 | Sending QMI_NAS_GET_PLMN_NAME_REQ_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=37.[0x25]
Feb 7 14:54:23 fx30s user.err Legato: =ERR= | modemDaemon[835]/le_pa T=main | pa_mrc_qmi.c ConvertHomeNetworkName() 889 | Failed to convert home network name
Feb 7 14:54:23 fx30s user.info Legato: INFO | modemDaemon[835]/le_pa T=main | pa_mrc_qmi.c pa_mrc_GetNetworkRegState() 2138 | called
Feb 7 14:54:23 fx30s user.err Legato: =ERR= | modemDaemon[835]/modemDaemon T=main | le_sms.c CloseSessionEventHandler() 2311 | SessionRef (0xb704ed5c) has been closed
Feb 7 14:54:33 fx30s user.err Legato: =ERR= | modemDaemon[835]/modemDaemon T=main | le_sms.c CloseSessionEventHandler() 2311 | SessionRef (0xb704f084) has been closed
Feb 7 14:54:33 fx30s user.warn Legato: -WRN- | modemDaemon[835]/le_pa T=unknown | pa_mrc_qmi.c ConvertPSState() 737 | PS state unknown
Feb 7 14:54:33 fx30s user.err Legato: =ERR= | dcsDaemon[793]/dcsDaemon T=main | dcsServer.c PacketSwitchHandler() 1881 | New PS state unknown PS state 5
Feb 7 14:54:54 fx30s user.warn Legato: -WRN- | modemDaemon[835]/le_pa T=unknown | pa_mrc_qmi.c ConvertPSState() 737 | PS state unknown
Feb 7 14:54:54 fx30s user.info Legato: INFO | modemDaemon[835]/modemDaemon T=main | le_mrc.c SignalStrengthIndHandlerFunc() 819 | Signal Strength Ind Handler called with RAT.5 and ss.-125
Feb 7 14:54:54 fx30s user.info Legato: INFO | modemDaemon[835]/modemDaemon T=main | le_mrc.c SignalStrengthIndHandlerFunc() 819 | Signal Strength Ind Handler called with RAT.2 and ss.-40
Feb 7 14:54:54 fx30s user.err Legato: =ERR= | modemDaemon[835]/modemDaemon T=main | le_sms.c CloseSessionEventHandler() 2311 | SessionRef (0xb704ed5c) has been closed
Feb 7 14:55:48 fx30s user.err Legato: =ERR= | modemDaemon[835]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 796 | Sending QMI_NAS_GET_PLMN_NAME_REQ_MSG_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=37.[0x25]
Feb 7 14:55:48 fx30s user.err Legato: =ERR= | modemDaemon[835]/le_pa T=main | pa_mrc_qmi.c ConvertHomeNetworkName() 889 | Failed to convert home network name
Feb 7 14:55:48 fx30s user.info Legato: INFO | modemDaemon[835]/le_pa T=main | pa_mrc_qmi.c pa_mrc_GetNetworkRegState() 2138 | called
Feb 7 14:55:49 fx30s user.err Legato: =ERR= | modemDaemon[835]/modemDaemon T=main | le_sms.c CloseSessionEventHandler() 2311 | SessionRef (0xb704f084) has been closed
indent preformatted text by 4 spaces
In last time I installed updated our Legato build where I included (in our added application) monitoring network registration state and:
- trying to turn radio off and on 5 seconds later (timer callback) if there is no registration to home network for an hour
- setting device in ULPM with wakeup 10 seconds later from timer
I did not seem to help (looks like stuck the same way again) but I did not have possibility to verify added functionality in development environment as I never experienced the same problem there.
There are more than 20 installations (part still with FW14 and part with my FW17 build) and most of them are working OK. Sevaral have however experienced described problem occasionally and currently on already 4 times in 2 week time (really one week if excluding offline time).
PS: code for automatic recovery attempt was broken but I cannot update it on device without somebody visiting weather station. This does not however invalidate observations done earlier when colleague visited place and checked state using USB connection.
