Hi all,
I’m testing my app on the FX30s LTE model. I’m not having any problems with my app so far, but I’m noticing that the registration state of the modem is changing consistently as follows:
> registered state = home (for one hour),
> registered state = searching/none (for half an hour),
> registered state = searching /none (for half an hour)....and so on.
I think the problem might be associated with the AirVantage Connector api, but I’m not sure.
Has anyone seen this behavior?
I stopped my app but it didn’t make any difference. See log below:
Thanks.
Regards,
Eddie
May 10 15:28:22 | avcDaemon[3607]/avcDaemon T=main | avcServer.c PollingTimerExpiryHandler() 1966 | Polling timer expired
May 10 15:28:22 | avcDaemon[3607]/avcDaemon T=main | avcClient.c avcClient_Connect() 906 | Starting retry timer of 15 min at index 0
May 10 15:28:22 | avcDaemon[3607]/avcDaemon T=main | avcServer.c PollingTimerExpiryHandler() 1982 | A connection to server will be made in 60 minutes
May 10 15:28:22 | dcsDaemon[3622]/dcsDaemon T=main | dcsServer.c TryStartTechSession() 1517 | Device is attached, ready to start a data session
May 10 15:28:27 | dcsDaemon[3622]/le_pa_dcs T=main | pa_dcs_linux.c AddNameserversToResolvConf() 310 | Set DNS ‘10.177.0.34’ ‘10.177.0.210’
May 10 15:28:27 | dcsDaemon[3622]/le_pa_dcs T=main | pa_dcs_linux.c AddNameserversToResolvConf() 310 | Set DNS ‘fd00:976a::9’ ‘fd00:976a::10’
May 10 15:28:27 | dcsDaemon[3622]/dcsDaemon T=main | dcsServer.c SetDefaultRouteAndDns() 1318 | DNS configuration is set successfully
May 10 15:28:32 | avcDaemon[3607]/avcDaemon T=main | avcClient.c BearerEventCb() 251 | Connected 1
May 10 15:28:39 | avcDaemon[3607]/avcDaemon T=main | avcServer.c ProcessUserAgreement() 1413 | Broadcast notification to applications
May 10 15:28:40 | avcDaemon[3607]/avcDaemon T=main | osTimer.c lwm2mcore_TimerIsRunning() 213 | Timer reference is NULL
May 10 15:28:41 | avcDaemon[3607]/avcDaemon T=main | osTimer.c lwm2mcore_TimerIsRunning() 213 | Timer reference is NULL
May 10 15:28:41 | avcDaemon[3607]/avcDaemon T=main | avcServer.c ProcessUserAgreement() 1413 | Broadcast notification to applications
May 10 15:28:42 | avcDaemon[3607]/avcDaemon T=main | osTimer.c lwm2mcore_TimerIsRunning() 213 | Timer reference is NULL
May 10 15:28:45 | avcDaemon[3607]/avcDaemon T=main | avcClient.c EventHandler() 544 | Session failure
May 10 15:28:45 | avcDaemon[3607]/avcDaemon T=main | avcClient.c EventHandler() 552 | Session failure on bootstrap server
May 10 15:28:45 | avcDaemon[3607]/avcDaemon T=main | avcServer.c ProcessUserAgreement() 1413 | Broadcast notification to applications
May 10 15:28:45 | avcDaemon[3607]/avcDaemon T=main | osTimer.c lwm2mcore_TimerStop() 179 | Timer reference is NULL
May 10 15:28:45 | dcsDaemon[3622]/dcsDaemon T=main | dcsServer.c TryStopDataSession() 1583 | Tearing down data session
May 10 15:28:46 | dcsDaemon[3622]/le_pa_dcs T=main | pa_dcs_linux.c pa_dcs_SetDefaultGateway() 568 | Default gateway or interface is empty
May 10 15:58:35 | modemDaemon[993]/modemDaemon T=main | le_mrc.c NetworkRejectIndHandler() 1170 | Network Reject Ind Handler called with RAT.8, mcc. and mnc.
May 10 15:58:35 | modemDaemon[993]/le_pa T=unknown | pa_mrc_qmi.c EventReportHandler() 1349 | Network Registration failed error code 15
May 10 15:58:37 | modemDaemon[993]/modemDaemon T=main | le_mrc.c SignalStrengthIndHandlerFunc() 686 | Signal Strength Ind Handler called with RAT.4 and ss.0
May 10 16:27:52 | modemDaemon[993]/le_pa T=main | pa_mrc_qmi.c pa_mrc_GetNetworkRegState() 2084 | called
May 10 16:28:22 | avcDaemon[3607]/avcDaemon T=main | avcServer.c PollingTimerExpiryHandler() 1966 | Polling timer expired
May 10 16:28:22 | avcDaemon[3607]/avcDaemon T=main | avcClient.c avcClient_Connect() 906 | Starting retry timer of 15 min at index 0
May 10 16:28:22 | avcDaemon[3607]/avcDaemon T=main | avcServer.c PollingTimerExpiryHandler() 1982 | A connection to server will be made in 60 minutes
May 10 16:28:22 | dcsDaemon[3622]/dcsDaemon T=main | dcsServer.c TryStartTechSession() 1517 | Device is attached, ready to start a data session
May 10 16:28:27 | dcsDaemon[3622]/le_pa_dcs T=main | pa_dcs_linux.c AddNameserversToResolvConf() 310 | Set DNS ‘10.177.0.34’ ‘10.177.0.210’
May 10 16:28:27 | dcsDaemon[3622]/le_pa_dcs T=main | pa_dcs_linux.c AddNameserversToResolvConf() 310 | Set DNS ‘fd00:976a::9’ ‘fd00:976a::10’
May 10 16:28:27 | dcsDaemon[3622]/dcsDaemon T=main | dcsServer.c SetDefaultRouteAndDns() 1318 | DNS configuration is set successfully
May 10 16:28:32 | avcDaemon[3607]/avcDaemon T=main | avcClient.c BearerEventCb() 251 | Connected 1
May 10 16:28:40 | avcDaemon[3607]/avcDaemon T=main | avcServer.c ProcessUserAgreement() 1413 | Broadcast notification to applications
May 10 16:28:41 | avcDaemon[3607]/avcDaemon T=main | osTimer.c lwm2mcore_TimerIsRunning() 213 | Timer reference is NULL
May 10 16:28:42 | avcDaemon[3607]/avcDaemon T=main | osTimer.c lwm2mcore_TimerIsRunning() 213 | Timer reference is NULL
May 10 16:28:42 | avcDaemon[3607]/avcDaemon T=main | avcServer.c ProcessUserAgreement() 1413 | Broadcast notification to applications
May 10 16:28:46 | avcDaemon[3607]/avcDaemon T=main | avcClient.c EventHandler() 544 | Session failure
May 10 16:28:46 | avcDaemon[3607]/avcDaemon T=main | avcClient.c EventHandler() 552 | Session failure on bootstrap server
May 10 16:28:46 | avcDaemon[3607]/avcDaemon T=main | avcServer.c ProcessUserAgreement() 1413 | Broadcast notification to applications
May 10 16:28:46 | avcDaemon[3607]/avcDaemon T=main | osTimer.c lwm2mcore_TimerStop() 179 | Timer reference is NULL
May 10 16:28:46 | dcsDaemon[3622]/dcsDaemon T=main | dcsServer.c TryStopDataSession() 1583 | Tearing down data session
May 10 16:28:47 | dcsDaemon[3622]/le_pa_dcs T=main | pa_dcs_linux.c pa_dcs_SetDefaultGateway() 568 | Default gateway or interface is empty
May 10 17:28:21 | modemDaemon[993]/le_pa T=unknown | pa_mrc_qmi.c EventReportHandler() 1349 | Network Registration failed error code 15
May 10 17:28:21 | modemDaemon[993]/modemDaemon T=main | le_mrc.c NetworkRejectIndHandler() 1170 | Network Reject Ind Handler called with RAT.8, mcc. and mnc.
May 10 17:28:22 | avcDaemon[3607]/avcDaemon T=main | avcServer.c PollingTimerExpiryHandler() 1966 | Polling timer expired
May 10 17:28:22 | avcDaemon[3607]/avcDaemon T=main | avcClient.c avcClient_Connect() 906 | Starting retry timer of 15 min at index 0
May 10 17:28:23 | avcDaemon[3607]/avcDaemon T=main | avcServer.c PollingTimerExpiryHandler() 1982 | A connection to server will be made in 60 minutes
May 10 17:28:23 | dcsDaemon[3622]/dcsDaemon T=main | dcsServer.c TryStartTechSession() 1517 | Device is attached, ready to start a data session
May 10 17:28:23 | modemDaemon[993]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 820 | Sending QMI_WDS_START_NETWORK_INTERFACE_REQ_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=14.[0x0e]
May 10 17:28:23 | modemDaemon[993]/le_pa T=main | pa_mdc_qmi.c StartSession() 1903 | Data connection failure Call End provided 45, Code 1
May 10 17:28:23 | modemDaemon[993]/le_pa T=main | pa_mdc_qmi.c StartSession() 1914 | Data connection failure Verbose Call End provided Type 3, Verbose 1078
May 10 17:28:28 | modemDaemon[993]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 820 | Sending QMI_WDS_START_NETWORK_INTERFACE_REQ_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=14.[0x0e]
May 10 17:28:28 | modemDaemon[993]/le_pa T=main | pa_mdc_qmi.c StartSession() 1903 | Data connection failure Call End provided 0, Code 3
May 10 17:28:28 | modemDaemon[993]/le_pa T=main | pa_mdc_qmi.c StartSession() 1914 | Data connection failure Verbose Call End provided Type 3, Verbose 1078
May 10 17:28:28 | modemDaemon[993]/modemDaemon T=main | le_mdc.c le_mdc_StartSession() 1008 | Get Connection failure 0, 3, 3, 1078
May 10 17:28:28 | modemDaemon[993]/modemDaemon T=main | le_mrc.c SignalStrengthIndHandlerFunc() 686 | Signal Strength Ind Handler called with RAT.4 and ss.-59
May 10 17:28:33 | dcsDaemon[3622]/le_pa_dcs T=main | pa_dcs_linux.c pa_dcs_SetDefaultGateway() 568 | Default gateway or interface is empty
May 10 17:43:23 | dcsDaemon[3622]/le_pa_dcs T=main | pa_dcs_linux.c pa_dcs_SetDefaultGateway() 568 | Default gateway or interface is empty
May 10 17:43:23 | avcDaemon[3607]/avcDaemon T=main | avcClient.c avcClient_Connect() 906 | Starting retry timer of 60 min at index 1
May 10 17:57:30 | modemDaemon[993]/le_pa T=main | pa_mrc_qmi.c pa_mrc_GetNetworkRegState() 2084 | called
May 10 17:57:36 | dcsDaemon[3622]/le_pa_dcs T=main | pa_dcs_linux.c AddNameserversToResolvConf() 310 | Set DNS ‘10.177.0.34’ ‘10.177.0.210’
May 10 17:57:36 | dcsDaemon[3622]/le_pa_dcs T=main | pa_dcs_linux.c AddNameserversToResolvConf() 310 | Set DNS ‘fd00:976a::9’ ‘fd00:976a::10’
May 10 17:57:36 | dcsDaemon[3622]/dcsDaemon T=main | dcsServer.c SetDefaultRouteAndDns() 1318 | DNS configuration is set successfully
May 10 17:57:41 | avcDaemon[3607]/avcDaemon T=main | avcClient.c BearerEventCb() 251 | Connected 1
May 10 17:57:48 | avcDaemon[3607]/avcDaemon T=main | avcServer.c ProcessUserAgreement() 1413 | Broadcast notification to applications
May 10 17:57:48 | avcDaemon[3607]/avcDaemon T=main | osTimer.c lwm2mcore_TimerIsRunning() 213 | Timer reference is NULL
May 10 17:57:49 | avcDaemon[3607]/avcDaemon T=main | osTimer.c lwm2mcore_TimerIsRunning() 213 | Timer reference is NULL
May 10 17:57:49 | avcDaemon[3607]/avcDaemon T=main | avcServer.c ProcessUserAgreement() 1413 | Broadcast notification to applications
May 10 17:57:50 | avcDaemon[3607]/avcDaemon T=main | osTimer.c lwm2mcore_TimerIsRunning() 213 | Timer reference is NULL
May 10 17:57:54 | avcDaemon[3607]/avcDaemon T=main | avcClient.c EventHandler() 544 | Session failure
May 10 17:57:54 | avcDaemon[3607]/avcDaemon T=main | avcClient.c EventHandler() 552 | Session failure on bootstrap server
May 10 17:57:54 | avcDaemon[3607]/avcDaemon T=main | avcServer.c ProcessUserAgreement() 1413 | Broadcast notification to applications
May 10 17:57:54 | avcDaemon[3607]/avcDaemon T=main | osTimer.c lwm2mcore_TimerStop() 179 | Timer reference is NULL
May 10 17:57:54 | dcsDaemon[3622]/dcsDaemon T=main | dcsServer.c TryStopDataSession() 1583 | Tearing down data session
May 10 17:57:54 | dcsDaemon[3622]/le_pa_dcs T=main | pa_dcs_linux.c pa_dcs_SetDefaultGateway() 568 | Default gateway or interface is empty
May 10 18:28:23 | avcDaemon[3607]/avcDaemon T=main | avcServer.c PollingTimerExpiryHandler() 1966 | Polling timer expired
May 10 18:28:23 | avcDaemon[3607]/avcDaemon T=main | avcClient.c avcClient_Connect() 906 | Starting retry timer of 15 min at index 0
May 10 18:28:23 | avcDaemon[3607]/avcDaemon T=main | avcServer.c PollingTimerExpiryHandler() 1982 | A connection to server will be made in 60 minutes
May 10 18:28:23 | dcsDaemon[3622]/dcsDaemon T=main | dcsServer.c TryStartTechSession() 1517 | Device is attached, ready to start a data session
May 10 18:28:27 | dcsDaemon[3622]/le_pa_dcs T=main | pa_dcs_linux.c AddNameserversToResolvConf() 310 | Set DNS ‘10.177.0.34’ ‘10.177.0.210’
May 10 18:28:27 | dcsDaemon[3622]/le_pa_dcs T=main | pa_dcs_linux.c AddNameserversToResolvConf() 310 | Set DNS ‘fd00:976a::9’ ‘fd00:976a::10’
May 10 18:28:27 | dcsDaemon[3622]/dcsDaemon T=main | dcsServer.c SetDefaultRouteAndDns() 1318 | DNS configuration is set successfully
May 10 18:28:32 | avcDaemon[3607]/avcDaemon T=main | avcClient.c BearerEventCb() 251 | Connected 1
May 10 18:28:39 | avcDaemon[3607]/avcDaemon T=main | avcServer.c ProcessUserAgreement() 1413 | Broadcast notification to applications
May 10 18:28:40 | avcDaemon[3607]/avcDaemon T=main | osTimer.c lwm2mcore_TimerIsRunning() 213 | Timer reference is NULL
May 10 18:28:40 | avcDaemon[3607]/avcDaemon T=main | avcServer.c ProcessUserAgreement() 1413 | Broadcast notification to applications
May 10 18:28:42 | avcDaemon[3607]/avcDaemon T=main | osTimer.c lwm2mcore_TimerIsRunning() 213 | Timer reference is NULL
May 10 18:28:45 | avcDaemon[3607]/avcDaemon T=main | avcClient.c EventHandler() 544 | Session failure
May 10 18:28:45 | avcDaemon[3607]/avcDaemon T=main | avcClient.c EventHandler() 552 | Session failure on bootstrap server
May 10 18:28:45 | avcDaemon[3607]/avcDaemon T=main | avcServer.c ProcessUserAgreement() 1413 | Broadcast notification to applications
May 10 18:28:45 | avcDaemon[3607]/avcDaemon T=main | osTimer.c lwm2mcore_TimerStop() 179 | Timer reference is NULL
May 10 18:28:45 | dcsDaemon[3622]/dcsDaemon T=main | dcsServer.c TryStopDataSession() 1583 | Tearing down data session
May 10 18:28:46 | dcsDaemon[3622]/le_pa_dcs T=main | pa_dcs_linux.c pa_dcs_SetDefaultGateway() 568 | Default gateway or interface is empty
May 10 18:58:02 | modemDaemon[993]/modemDaemon T=main | le_mrc.c NetworkRejectIndHandler() 1170 | Network Reject Ind Handler called with RAT.8, mcc. and mnc.
May 10 18:58:02 | modemDaemon[993]/le_pa T=unknown | pa_mrc_qmi.c EventReportHandler() 1349 | Network Registration failed error code 15
May 10 18:58:04 | modemDaemon[993]/modemDaemon T=main | le_mrc.c SignalStrengthIndHandlerFunc() 686 | Signal Strength Ind Handler called with RAT.4 and ss.-70
