We’re installing a FX30S LTE-M Global in Japan using a NTT Docomo data only account. On power up the modem goes into a reboot loop. If the SIM chip is removed, the modem boots up normally.
I’ve looked through the console log (attached) putty.txt (41.4 KB)
but not sure what is causing the problem. Any help is appreciated! Thanks.
WP77XX firmware version R14.1 (Generic) worked. Modem now boots-up normally with SIM card installed. I’m able to register and connect to cell network.
Now I have to rebuild my app with R14.1 firmware. Do you have a link with instructions for building in VSCode? Up to now I have been using Window Developer Studio and I know it’s no longer supported by SierraWireless.
We can’t use the wp77xx latest firmware because we are using the FX30S GPIOs which are not supported by the wp77xx latest firmware. So, until new FX30S firmware is released, we are going to have to continue using the current released FX30S firmware.
Having said that, what other troubleshooting options can you give me? Can we disable the watchdog so the modem stops rebooting long enough for us to determine what the problem is?
Question, What are the parts I need to include in the custom firmware build to add support for the serial UART1, the modem’s two LEDs(GPIO47 & GPIO48), and GPIO56?
We currently have an ongoing project that we need these modems to work on. The end of July is to far out to have our customers wait, plus we never identified what was making the modems reboot themselves. What if the new firmware at the end of July does the same thing?
I would like to keep troubleshooting the modems with the FX30 R11 firmware to find the problem. Any ideas on what I can do to find the cause are greatly appreciated!
Currently since the modems are in a reboot loop, I can’t get in to it to diagnose. Any thoughts on what I can do to at least look at what is making the modem fail and reboot.
Hi @eddie435,
From the logs, the modem is crashing.
Could you clarify which carrier image you’re installing? Make sure you use the Generic GCF image.
There seems to be an issue with the modem firmware image on Docomo with your SIM. Would it be possible to try a SIM for a different carrier in Japan?
As far as I know, there shouldn’t be an issue on Docomo running R9.1 and R11. If you have to use the Docomo SIM, could you try the Sierra carrier image?
Is the issue occurring on all your units?
Could you please post the output of:
ATI
ATI8
AT!FWD?ALVER
AT!FWD?DEVTYPE
AT!IMPREF?
AT!IMAGE?
AT!GSTATUS?
