Chris,
The carrier images I tested are the following:
- FX30_WP77xx_full_R9.1.1.013-generic.cwe - FAILED
- FX30_WP77xx_full_R9.1.1.013-sierra.cwe - FAILED
- FX30_WP77xx_full_R11.0.0.007-generic_gcf-SWI9X06Y_02.22.12.00.cwe - FAILED
- WP77xx_Release14.1_GENERIC_GCF_PTCRB.spk - WORKED
At the moment we don’t have another carrier SIM available, but will try to get one soon for testing.
Question: Are differences in the SIM cards we should be concerned with? In other words, Are there SIMs specifically for 4G and others for 5G which might be causing the modem to crash?
Tried the Sierra carrier image with no success.
We have multiple FX30S units and multiple Docomo SIMs, all have had the same results.
Here is the output requested:
at
ati
Model: FX30S(WP7702)
Revision: SWI9X06Y_02.16.06.00 7605a6 jenkins 2018/06/20 17:56:12
IMEI: 354723090173377
IMEI SV: 2
FSN: VU028585940210
+GCAP: +CGSM
ati8
Legato Ver: 18.06.1_03c5394b4c271c054ae58a494f160e37
Yocto Ver: SWI9X06Y_02.18.05.00 2019-01-29_11:20:10
OS Ver: Linux version 3.18.44 (jenkins@CAKEL-EV-ALBLD2) (gcc version 6.2.0 (GCC) ) #2 PREEMPT Tue Jan 29 11:21:07 PST 2019
LK Ver: 1.3.0_838aec2863
RootFS Ver: SWI9X06Y_02.18.05.00 2019-01-29_11:20:10
UserFS Ver: unknown
MCU Ver: 002.009
at!fwd?ALVER
R9.1.1.013
AT!FWD?DEVTYPE
FX30S(WP7702)
at!IMPREF?
!IMPREF:
preferred fw version: 02.16.06.00
preferred carrier name: SIERRA
preferred config name: SIERRA_001.000_002
current fw version: 02.16.06.00
current carrier name: SIERRA
current config name: SIERRA_001.000_002
at!image?
FW 1 GOOD 1 0 0 ?? 02.16.06.00?
FW 2 EMPTY 0 0 0
FW 3 EMPTY 0 0 0
Max FW images: 3
Active FW image is at slot 1
PRI FF GOOD 0 0 0 001.026_000 02.16.06.00_ATT
PRI FF GOOD 0 0 0 001.028_002 02.16.06.00_GENERIC
PRI FF GOOD 0 0 0 001.000_002 02.16.06.00_SIERRA
Max PRI images: 50
at!gstatus?
!GSTATUS:
Current Time: 1181 Temperature: 24
Reset Counter: 1 Mode: ONLINE
System mode: CDMA PS state: Not attached
Here’s the log of what happened when we inserted the SIM while the modem was ON. After a bit the modem crashed and rebooted.
Jan 6 00:01:55 | uartMode[1826]/swiQmi T=main | swiQmi.c InitService() 379 | Init QMI service QMI_SERVICE_DMS (2)
Jan 6 00:01:55 | uartMode[1826]/swiQmi T=main | swiQmi.c PrintServiceDetails() 355 | Service.2: library_version.6 idl_version.1 service_id.0x2 idl_minor_version.57
Jan 6 00:01:55 | QMUXD: WARNING qmi_qmux_if_pwr_up_init failed! rc=-6
Jan 6 00:01:55 | uartMode[1827]/swiQmi T=main | swiQmi.c StartService() 113 | qmi_client_get_service_list rc=0, numServices=1
Jan 6 00:01:55 | uartMode[1826]/swiQmi T=main | swiQmi.c StartService() 113 | qmi_client_get_service_list rc=0, numServices=1
Jan 6 00:01:55 | uartMode[1828]/swiQmi T=main | swiQmi.c InitService() 379 | Init QMI service QMI_SERVICE_DMS (2)
Jan 6 00:01:55 | uartMode[1828]/swiQmi T=main | swiQmi.c PrintServiceDetails() 355 | Service.2: library_version.6 idl_version.1 service_id.0x2 idl_minor_version.57
Jan 6 00:01:55 | uartMode[1828]/swiQmi T=main | swiQmi.c StartService() 113 | qmi_client_get_service_list rc=0, numServices=1
Jan 6 00:02:12 | modemDaemon[990]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 820 | Sending QMI_UIM_READ_TRANSPARENT_REQ_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=3.[0x03]
Jan 6 00:02:12 | modemDaemon[990]/le_pa T=main | pa_sim_qmi.c RetrieveSimApplicationType() 1942 | SIM card error 0)
Jan 6 00:02:12 | modemDaemon[990]/le_pa T=main | pa_sim_qmi.c GetSimApplicationType() 2066 | Cannot get the SIM application type
Jan 6 00:02:12 | modemDaemon[990]/le_pa T=main | pa_sim_qmi.c pa_sim_GetIMSI() 2889 | Unknown SIM application
Jan 6 00:02:12 | modemDaemon[990]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 820 | Sending QMI_UIM_GET_EID_RESP_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=71.[0x47]
Jan 6 00:02:12 | modemDaemon[990]/le_pa T=main | pa_sim_qmi.c pa_sim_GetCardEID() 2836 | Failed to get the EID
Jan 6 00:02:12 | modemDaemon[990]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 820 | Sending QMI_PBM_READ_RECORDS_REQ_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=41.[0x29]
Jan 6 00:02:12 | modemDaemon[990]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 820 | Sending QMI_DMS_GET_MSISDN_REQ_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=37.[0x25]
Jan 6 00:02:13 | cellNetService[954]/cellNetService T=main | cellNetServiceServer.c LoadSimFromSecStore() 180 | Sim-1 is absent
Jan 6 00:02:13 | modemDaemon[990]/le_pa T=main | pa_mrc_qmi.c pa_mrc_GetNetworkRegState() 2084 | called
Jan 6 00:02:15 | modemDaemon[990]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 820 | Sending QMI_UIM_READ_TRANSPARENT_RESP_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=82.[0x52]
Jan 6 00:02:15 | modemDaemon[990]/le_pa T=main | pa_sim_qmi.c GetUsimIMSI() 2114 | Failed to copy IMSI
Jan 6 00:02:15 | modemDaemon[990]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 820 | Sending QMI_UIM_GET_EID_RESP_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=71.[0x47]
Jan 6 00:02:15 | modemDaemon[990]/le_pa T=main | pa_sim_qmi.c pa_sim_GetCardEID() 2836 | Failed to get the EID
Jan 6 00:02:15 | modemDaemon[990]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 820 | Sending QMI_PBM_READ_RECORDS_REQ_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=41.[0x29]
Jan 6 00:02:15 | modemDaemon[990]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 820 | Sending QMI_DMS_GET_MSISDN_REQ_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=37.[0x25]
Jan 6 00:02:15 | modemDaemon[990]/le_pa T=main | pa_mrc_qmi.c pa_mrc_GetNetworkRegState() 2084 | called
Jan 6 00:02:17 | modemDaemon[990]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 820 | Sending QMI_UIM_READ_TRANSPARENT_RESP_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=82.[0x52]
Jan 6 00:02:17 | modemDaemon[990]/le_pa T=main | pa_sim_qmi.c GetUsimIMSI() 2114 | Failed to copy IMSI
Jan 6 00:02:17 | modemDaemon[990]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 820 | Sending QMI_UIM_GET_EID_RESP_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=71.[0x47]
Jan 6 00:02:17 | modemDaemon[990]/le_pa T=main | pa_sim_qmi.c pa_sim_GetCardEID() 2836 | Failed to get the EID
Jan 6 00:02:17 | modemDaemon[990]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 820 | Sending QMI_PBM_READ_RECORDS_REQ_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=41.[0x29]
Jan 6 00:02:17 | modemDaemon[990]/swiQmi T=main | swiQmi.c swiQmi_CheckResponse() 820 | Sending QMI_DMS_GET_MSISDN_REQ_V01 failed: rc=0 (), resp.result=1.[0x01], resp.error=37.[0x25]
Jan 6 00:02:17 | modemDaemon[990]/le_pa T=main | pa_mrc_qmi.c pa_mrc_GetNetworkRegState() 2084 | called
------------ [Thu, 17 Jun 2021 10:50:51 +0900] Disconnect ------------
