I tried both and my FX30 is still stuck in the boot sequence.
Even downgrade to FW9.1 (and force overlay reset) doesn’t help.
If it can help, here is the boot sequence log (from the serial port):
▒▒▒▒▒▒ѱ▒▒▒▒Ɂj▒%E▒E▒
R▒+▒W++K▒▒▒
j▒▒[10] Qseecom Init Done in Appsbl
[10] secure app region addr=0x87900000 size=0x280000[10] TZ App region notif returned with status:0 addr:87 900000 size:2621440
[20] TZ App log region register returned with status:0 addr:82675000 size:4096
[30] Qseecom TZ Init Done in Appsbl
[30] ERROR: No devinfo partition found
[30] Neither 'config' nor 'frp' partition found
[40] ERROR: No misc partition found
[1100] SSMEM init OK[1100] ssmem_get: region 20 not exists[1190] DEBUG: cmdline has root=
[1310] Channel alloc freed
[ 0.000000] GIC CPU mask not found - kernel will fail to boot.
[ 0.000000] MPM 1 irq mapping errored -517
[ 0.215740] spmi_pmic_arb 200f000.qcom,spmi: PMIC Arb Version-2 0x20010000
[ 0.231247] msm_mpm_dev_probe(): Cannot get clk resource for XO: -517
[ 0.234404] smd_channel_probe_now: allocation table not initialized
[ 0.242143] msm_thermal:msm_thermal_dev_probe Failed reading node=/soc/qcom,msm-thermal, key=qcom,online -hotplug-core. err:-517
[ 0.270306] msm_mpm_dev_probe(): Cannot get clk resource for XO: -517
[ 0.273312] msm_thermal:get_kernel_cluster_info CPU0 topology not initialized.
[ 0.274237] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
[ 0.274253] msm_thermal:get_cpu_freq_plan_len Error reading CPU0 freq table len. error:-19
[ 0.274967] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
[ 0.274984] msm_thermal:get_cpu_freq_plan_len Error reading CPU0 freq table len. error:-19
[ 0.275000] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
[ 0.275013] msm_thermal:get_cpu_freq_plan_len Error reading CPU0 freq table len. error:-19
[ 0.369872] AXI: msm_bus_scale_register_client(): msm_bus_scale_register_client: Bus driver not ready.
[ 0.371755] AXI: msm_bus_scale_register_client(): msm_bus_scale_register_client: Bus driver not ready.[ 0.372050] i2c-msm-v2 78b8000.i2c: NACK: slave not responding, ensure its powered: msgs(n:1 cur:0 tx) bc( rx:0 tx:2) mode:FIFO slv_addr:0x3a MSTR_STS:0x081343c8 OPER:0x00000090
[ 0.420608] swimcu_appl_psm_duration_get: return status 0
[ 0.420636] swimcu_pm_rtc_restore: invalid PSM elapsed time: 0
[ 0.478178] i2c-msm-v2 78b8000.i2c: NACK: slave not responding, ensure its powered: msgs(n:2 cur:0 tx) b c(rx:3 tx:1) mode:FIFO slv_addr:0x22 MSTR_STS:0x091343c8 OPER:0x00000010
[ 0.478251] pca953x 4-0022: failed reading register
[ 0.479320] i2c-msm-v2 78b8000.i2c: NACK: slave not responding, ensure its powered: msgs(n:2 cur:0 tx) b c(rx:2 tx:2) mode:FIFO slv_addr:0x1a MSTR_STS:0x091343c8 OPER:0x00000010
[ 0.479391] wm8944 4-001a: Failed to read ID register
[ 0.483415] msm_bus_fabric_init_driver
[ 0.497922] SWI ssmem_framework_init: SSMEM init OK
[ 0.687043] scm_call failed with error code -4
[ 0.687063] msm_audio_protect_memory_region: SCM call failed, scm_call_ret -95 tz_resp 0
[ 0.692561] uart_tx_gpio is not available
[ 0.692583] uart_rx_gpio is not available
[ 0.692603] uart_cts_gpio is not available
[ 0.692623] uart_rfr_gpio is not available
[ 0.693474] AXI: get_pdata(): Error: Client name not found
[ 0.693484] AXI: msm_bus_cl_get_pdata(): client has to provide missing entry for successful registration
[ 0.693493] msm_serial_hsl_probe: Bus scaling is disabled
[ 0.995524] sps: BAM device 0x07984000 is not registered yet.
[ 1.045403] unable to find DT imem DLOAD mode node
[ 1.049492] unable to find DT imem EDLOAD mode node
[ 1.054501] unable to find DT imem dload-type node
[ 1.058978] Failed to disable secure wdog debug: -4
[ 1.091045] devfreq soc:qcom,cpubw: Couldn't update frequency transition information.
[ 1.098078] coresight_event: error registering on panic -38
[ 1.104677] sdhci_msm 7864900.sdhci: sdhci_msm_pm_qos_parse_irq: error -22 reading irq cpu
[ 1.118242] coresight-tmc 6025000.tmc: failed to get flush cti
[ 1.124449] coresight-tmc 6025000.tmc: failed to get reset cti
[ 1.187956] mdm9607-asoc-snd soc:sound-wm8944: Defering mdm_asoc_machine_probe, q6_state 0
[ 1.210667] mdm9607-asoc-snd soc:sound-wm8944: Defering mdm_asoc_machine_probe, q6_state 0
[ 1.218495] wl12xx GPIO: 131
[ 1.241264] mdm9607-asoc-snd soc:sound-wm8944: Defering mdm_asoc_machine_probe, q6_state 0
[ 1.256401] calculate_residency: residency < 0 for LPM
[ 1.260950] mdm9607-asoc-snd soc:sound-wm8944: Defering mdm_asoc_machine_probe, q6_state 0
[ 1.280148] parse_cpu_levels: idx 1 420
[ 1.282950] calculate_residency: residency < 0 for LPM
[ 1.288075] parse_cpu_levels: idx 2 500
[ 1.300132] parse_cpu_levels: idx 2 3040
[ 1.304065] mdm9607-asoc-snd soc:sound-wm8944: Defering mdm_asoc_machine_probe, q6_state 0
[ 1.321289] mdm9607-asoc-snd soc:sound-wm8944: Defering mdm_asoc_machine_probe, q6_state 0
cat: can't open '/sys/class/gpio/gpiochip996/label': No such file or directory
sh: tca6416: unknown operand
cat: can't open '/sys/class/gpio/gpiochip988/label': No such file or directory
sh: tca6424: unknown operand
ima: setting up IMA subsystem...
ima: feature not supported
The proc node does not exist
mount root fs from partition (rootfs|system)
Non-secure.
UBI device number 0, total 120 LEBs (30474240 bytes, 29.1 MiB), available 0 LEBs (0 bytes), LEB size 253952 bytes (248.0 KiB)
rootfs roothash: 681542d6bab41e8c2f7ddfb6edae36f844b0fb67b38b61a4f789fa7e57e550c1
rootfs: dev '/dev/ubiblock0_0' 'squashfs'
mount /dev/mapper/rt
rootfs: mounting took 0ms
init started: BusyBox v1.24.1 (2019-01-29 10:47:12 PST)
/etc/init.d/rcS: /etc/run.env: line 168: can't create /etc/hostname: Read-only file system
rcS: Executing mount_essential_fs...
rcS: Executing simple_network...
rcS: Executing check_recovery...
/etc/init.d/factory_default_recovery.sh: /etc/run.env: line 168: can't create /etc/hostname: Read-only file system
rcS: Executing run_S_scripts...
/etc/rcS.d/S02mount_early: /etc/run.env: line 168: can't create /etc/hostname: Read-only file system
S02mount_early: Executing mount_early_pseudo...
S02mount_early: Executing mount_early_other...
S02mount_early: Executing mount_early_create_dirs...
S02mount_early: Executing yaffs2_kern_supported_init...
S02mount_early: Executing mount_early_user_start...
S02mount_early: RO rootfs fudge allowed.
S02mount_early: User is forcing userapp file system to be ubifs.
S02mount_early: Trying to mount UBIFS on /mnt/flash using [usrquota,grpquota,rw] mount options...
UBI device number 3, total 524 LEBs (133070848 bytes, 126.9 MiB), available 5 LEBs (1269760 bytes, 1.2 MiB) , LEB size 253952 bytes (248.0 KiB)
S02mount_early: Performing quota check on file system mounted at /mnt/flash
S02mount_early: UBIFS volume successfully mounted on /mnt/flash
S02mount_early: Executing mount_early_legato_start...
sh: 200: unknown operand
mount Legato from partition lefwkro
S02mount_early: Non-secure.
UBI device number 2, total 35 LEBs (8888320 bytes, 8.5 MiB), available 0 LEBs (0 bytes), LEB size 253952 by tes (248.0 KiB)
S02mount_early: SQUASHFS successfully mounted on /mnt/legato
S02mount_early: Executing mount_early_userrw_start...
S02mount_early: Mounting swirw file system as UBIFS
S02mount_early: Trying to mount UBIFS on /mnt/userrw using [usrquota,grpquota,rw] mount options...
UBI device number 4, total 100 LEBs (25395200 bytes, 24.2 MiB), available 2 LEBs (507904 bytes, 496.0 KiB), LEB size 253952 bytes (248.0 KiB)
S02mount_early: Performing quota check on file system mounted at /mnt/userrw
S02mount_early: UBIFS volume successfully mounted on /mnt/userrw
S02mount_early: swirw mounted to /mnt/userrw
/etc/rcS.d/S03confighw.sh: /etc/run.env: line 168: can't create /etc/hostname: Read-only file system
S03confighw.sh: Kernel internal entropy pool filler is available, increasing write_wakeup_threshold to 3072
chown: unknown user messagebus
chgrp: unknown group messagebus
Starting system message bus: start-stop-daemon: unknown user messagebus
dbus.
/etc/rcS.d/S07mount_unionfs: /etc/run.env: line 168: can't create /etc/hostname: Read-only file system
S07mount_unionfs: RO rootfs fudge allowed.
S07mount_unionfs: Overlay over /etc is allowed
Mounting local filesystems...
[ 8.971280] UBIFS error (pid: 489): cannot open "ubi0:usrfs", error -19mount: mounting ubi0:usrfs on /usr failed: No such device
mount modem from partition modem
MTD : Detected block device : /firmware for modem
UBI device number 1, total 128 LEBs (32505856 bytes, 31.0 MiB), available 0 LEBs (0 bytes), LEB size 253952 bytes (248.0 KiB)
Initializing random number generator...
Switching to composition sierra_dev (1199:68C0)
[ 9.666697] enable_store: android_usb: already disabled
microcom: can't open '/dev/ttyAT': No such device
Configuring network interfaces... [ 10.311074] gbam_connect_work: gbam_connect_work: Bam channel is not ready
done.
Starting syslogd/klogd: [ 10.395929] qti_ctrl_queue_notify: qti_ctrl_queue_notify: rmnet ctrl file handler cd663780 is not open
[ 10.405059] qti_ctrl_queue_notify: qti_ctrl_queue_notify: rmnet ctrl file handler cd663780 is not opendone
Starting diagrebootapp: done
$Starting qcom_time:
starting time-daemon
Starting time_services: ifconfig: SIOCGIFFLAGS: No such device
done
ifconfig: SIOCSIFADDR: No such device
Legato start sequence
start_at_cmux_le: Starting DS_MUX:
start_at_cmux_le: UART1_SERVICE=DISABLED
restart_at_uart: NO UART map for AT service
start_at_cmux_le: DS_MUX daemon on USB
start_at_cmux_le: Done start_at_cmux_le script.
update-ld-cache: Removing stale mount [/etc/ld.so.conf]...
update-ld-cache: Removing stale mount [/etc/ld.so.cache]...
update-ld-cache: Updating ld.so.cache using [/legato/systems/current/lib]...
update-ld-cache: Updating /etc/ld.so.cache ...
[ 12.899669] i2c-msm-v2 78b8000.i2c: msm_bus_scale_register_client(mstr-id:86):0xa (ok)
[ 12.937683] i2c-msm-v2 78b8000.i2c: NACK: slave not responding, ensure its powered: msgs(n:1 cur:0 tx) bc(rx:0 tx:2) mode:FIFO slv_addr:0x3a MSTR_STS:0x001363c8 OPER:0x00000090
cp: can't stat '/etc/resolv.conf': No such file or directory
[ 15.266938] M-Notify: General: 7
mount: mounting /tmp/resolv.conf on /etc/resolv.conf failed: No such file or directory
[ 15.314925] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: Failed to add route MM_DL5 -> MultiMedia5 -> TERT_MI2S_RX Audio Mixer
[ 15.338790] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: Failed to add route MM_DL8 -> MultiMedia8 -> TERT_MI2S_RX Audio Mixer
[ 15.356695] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: Failed to add route INT_FM_TX -> INTERNAL_FM_TX -> SEC_MI2S_RX Port Mixer
[ 15.403852] diag: In diag_send_feature_mask_update, control channel is not open, p: 0, c0fe3904
[ 15.568060] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: no sink widget found for MM_UL28
[ 15.586777] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: Failed to add route MultiMedia28 Mixer -> direct -> MM_UL28
