For the first usage, after configured the root password, I configured the SIM Card :
cm sim mode MANUAL
cm sim select EXTERNAL_SLOT_1
Then checked the SIM Card :
cm sim
SIM card is inserted and unlocked (LE_SIM_READY).
cm sim info
Type: EXTERNAL_SLOT_1
ICCID: 8988247000014553367
Home Network Operator: Transatel
EID:
IMSI: 901370001455336
After that, i configured the APN :
AT+CGDCONT=1,“IP”,“mobiledata”
And then checked it :
AT+CGDCONT?
+CGDCONT: 1,"IP","mobiledata","0.0.0.0",0,0,0,0
But the modem did not attached to the Network.
Here is some diag if required :
root@fx30:~#
root@fx30:~#
root@fx30:~#
root@fx30:~# cm sim
root@fx30:~#
root@fx30:~#
root@fx30:~#
root@fx30:~#
root@fx30:~# cm sim info
EID:
Phone Number:
root@fx30:~#
root@fx30:~#
root@fx30:~#
root@fx30:~#
root@fx30:~# cm info
Device: FX30(WP7702)
IMEI: 354723091120583
IMEISV: 8
FSN: AT342525081510
Firmware Version: SWI9X06Y_02.36.08.09 c094f4 jenkins 2022/06/24 03:14:28
Bootloader Version: SWI9X06Y_02.36.08.09 c094f4 jenkins 2022/06/24 03:14:28
MCU Version: 002.015
PRI Part Number (PN): 9910239
PRI Revision: 001.002
Carrier PRI Name: GENERIC
Carrier PRI Revision: 001.079_000
SKU: 1104770
Last Reset Cause: Power Down
Resets Count: Expected: 19 Unexpected: 0
root@fx30:~#
root@fx30:~#
root@fx30:~#
root@fx30:~#
root@fx30:~# cm data
Index: 1
APN: mobiledata
PDP Type: IPV4
Connected: no
root@fx30:~#
root@fx30:~#
root@fx30:~#
root@fx30:~#
root@fx30:~# cm radio
Power: ON
Current Network Operator:
Current RAT: Module not registered on network, RAT not available
Status: Not registered but currently searching for a new operator (LE_MRC_REG_SEARCHING)
Signal: No signal strength (0)
PS: Packet Switched Not registered (LE_MRC_REG_NONE)
root@fx30:~#
root@fx30:~#
root@fx30:~#
root@fx30:~#
root@fx30:~# microcom -E /dev/ttyAT
AATTEE00
ATI
Model: FX30(WP7702)
Revision: SWI9X06Y_02.36.08.09 c094f4 jenkins 2022/06/24 03:14:28
IMEI SV: 8
FSN: AT342525081510
+GCAP: +CGSM
AT+CPIN?
+CPIN: READY
AT+CREG?
+CREG: 0,2
AT+CGREG?
+CGREG: 0,4
AT+COPS?
+COPS: 0
AT+CGACT?
+CGACT: 1,0
AT!GSTATUS?
!GSTATUS:
Current Time: 307 Temperature: 29
Reset Counter: 1 Mode: ONLINE
System mode: LTE PS state: Not attached
IMS reg state: UNKNOWN IMS mode: Not Support
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
LTE band: No band LTE bw: Unknown
LTE Rx chan: 1 LTE Tx chan: ---
LTE CA state: ACTIVE LTE Scell band:No band
LTE Scell bw:Unknown LTE Scell chan: 0
EMM state: Deregistered Attach Needed
RRC state: RRC Idle
PCC RxM RSSI: 0 RSRP (dBm): 0
PCC RxD RSSI: 0 RSRP (dBm): 0
SCC RxM RSSI: 0 RSRP (dBm): 0
SCC RxD RSSI: 0 RSRP (dBm): 0
Tx Power: -- TAC: 0000 (0)
RSRQ (dB): 0 Cell ID: 00000000 (0)
SINR (dB): 0
AT+CGDCONT?
