FX30 with 4G SIM?
Hi, i have an FX30 and i put a 4G Sim card in it. I know the FX30 can only utilize 3G, but this 4G sim card should still work in it right? The FX30 will just connect to 3G instead and be fine, correct?
I’m having issues getting connected to the internet.
If you need any other information just let me know, thanks!
@Jason26,
Generically speaking, yes, LTE SIM’s are configured to work on LTE and 3G for a given network. The below AT commands should give you an idea as to what is happening.
at+cmee=1
ati
at+cpin?
at+cimi
at!gstatus?
at+cops?
at+cops=?     //This will take a minute or so to complete
at+cgdcont?
at!pcinfo?
Hey Matt, Thanks for the reply.
Where would i put these commands? My employer, Deif, is beginning to use these as a standard for a remote monitoring solution and we have our own setup page that probably differs from yours slightly (see screenshot).
In the modem it says “registration was denied, usually becuase of invalid access credentials”. What access credentials do i need?
@Jason26,
If you have plugged into the USB port on the front of the device then you will have had 3 serial ports enumerate onto your Windows system (assuming you have installed the right drivers) you can then use a terminal program (like teraterm) to connect to the third port (it may have ‘AT commands’ written next to it or not) to send the commands to it.
Aah okay got it. So i have the below info. Not sure what it all means though…
at+cmee=1
ati
Model: FX30
Revision: SWI9X15Y_07.11.22.00 r33729 CARMD-EV-FRMWR1 2017/01/11 18:04:06
MEID: A000007D376820
ESN: 12814559877, 80DE2A85
IMEI: 353984080058025
IMEI SV: 43
FSN: LL705201460910
+GCAP: +CGSM,+DS,+ES
at+cpin?
+CPIN: READY
at+cimi
311480410727276
at!gstatus
ERROR
at+cops?
+COPS: 0,0,“Limited Service”,2
at+cops=?
+CME ERROR: 30
at+cgdcont?
ERROR
at!pcinfo?
State: Online
LPM force flags - W_DISABLE:0, User:0, Temp:0, Volt:0, BIOS:0, GOBIIM:0
W_DISABLE: 0
Poweroff mode: 0
LPM Persistent: 0
@Jason26,
The gstatus command needs a ? at the end.
Having looked at the IMSI number of the SIM 311480410727276, this tells me it is a Verizon SIM (311 US, 480 Verizon), unfortunately Verizon only operate an LTE (4G) network and the FX30 is 2G/3G, it is currently camped on 3G ("+COPS: 0,0,“Limited Service”,2") so it can probably see AT&T.
So that is your basic problem, you are trying to use a network that the FX30 is not desgined to work with.
Aah i seee. Okay, so i should probably get an AT&T 3G Sim card and that should hopefully fix my issue with connection.
Does the below tell you anything else?
at!gstatus?
!GSTATUS:
Current Time: 7117 Temperature: 30
Bootup Time: 0 Mode: ONLINE
System mode: WCDMA PS state: Not attached
WCDMA band: WCDMA 1900
WCDMA channel: 9890
GMM (PS) state:DEREGISTERED LIMITED SERVICE
MM (CS) state: IDLE LIMITED SERVICE
WCDMA L1 State:L1M_PCH_SLEEP LAC: 1BEC (7148)
RRC State: DISCONNECTED UTRAN Cell ID: 02BF A661 (703 42593)
RxM RSSI C0: -73 RxD RSSI C0: -106
RxM RSSI C1: -106 RxD RSSI C1: -106
IMS Reg State: UNKNOWN IMS Mode: Not Support
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
@Jason26,
It just confirms what I have said, the unit is just camped on the only network it can see, which is a 3G one.
The SIM you get will be able to get onto any of AT&T’snetworks that a given unit can see.
