- I mounted the ethernet card fxte02 in modem fxt009.
I found the commands to start the ethernet and to take the IP address in the DHCP.
When I turn off the fxt009 and the turn on, the ethernet is off. So I have to repeat the AT commands
I don’t know in which way I can save the configuration.
When I turn on the Fxt009 , I need that it will activate the ethernet and get the ip address in automatic.
Can Someone help me?
- I need to use a Com port emulator with Fxt009+Fxte02.
DO you know if there is a Sierra official Com port emulator for the FXt009?
I tried some Com port simulator, but I can’t find the correct socket to connect to the modem.
Which is the port to use?
I saw there are 16 socket available by default.
The application I use just try to connect on a local com.
With Serial and USB is possible, but I don’t in which way use the Modem with the Ip address activated without a Com port emulator.
Any Idea?
Thank you very much
Massimiliano
