FXT003 - get up and running
#1
Hi all
I have been thrown in the deep-end with this, so please take it easy on me. I got this modem hoping that I could do the following:
  • Be online - using the data allowance as given by my carrier (Telstra NextG SIM with voice and data)
  • Make voice calls (using the ATD command)
  • Send MMS (send a JPG to a phone using the appropriate AT command)
I have a AirLink FXT003 which I was told could do all these things. I was hoping for it to be as simple as getting the modem online using whatever means necessary (using the Discovery Tool even), then I was hoping to target a COM port that’s connected to the modem, send an ATD command to it and be able to make a voice call.
Having installed the modem, I soon discovered that it’s not going to be that simple. Looks like I need to use the Developer Studio (2.0) to write a C/C++ application to do this.
However after getting the c++ ‘Hello World’ example off the ground, I found myself fumbling in all different directions trying to find a way I could write what I need.
So, I’m asking for ‘n00b’ direction here. After looking around this forum, I can’t find what I’m looking for so I hope this thread will help me and also act as a ‘tutorial’ of sorts to others in my situation.
  • Can I achieve what I set out to do?
  • If so, how? (can anyone point me to some sample code, share insights)
Thanks for your help, I appreciate it.
#2
You can find MMS sample in Developer Studio if you included “WIP Open AT Plugin Package” under package selection when creating a new project.
Hope this help.
L
#3
Thanks lotam
I found that I can
-make the voice call using ATDxxxxxxxx;
-send the MMS using AT commands
-connect to the internet using the standard dialup mechanism.
So no programing using the scary Dev Studio is needed - phew!
#4
Yes, MMS was supported in WIP AT.
“scary Dev Studio”…
Do you mean it? lol
#5
I’ve been using the Dev Studio for the past month with a couple of the FXT009’s and I must admit it did feel like I was thrown into the deep end by my boss.
But keeping at it and I have found that it is getting easier. If you keep at it and want to go the development route I do recommend it.
#6
I agree… . it was quite scary to dive into it head first… especially for the relatively small amount of integration with the modem (dial internet,sms) … the AT command set saved me . .
