FX30 Ethernet question
We are considering using the FX30 as a way to get quickly to market for an eventual WP7603 based system of our own design (we followed the same path successfully with the FX100-Q2698 and FXT009-Q2687 Fastracks). I was wondering if there is a full PTS available for the FX30? Also is there information on its Ethernet implementation including the internal connection method (SPI? SDIO? HSIC?) and controller used? The reason is we would likely use the same controller to minimize the development required.
Hi there,
You can download the datasheet from here:
The ethernet implementation is HSIC using a LAN9500 chip.
BR,
Chris
