FX-130 in AU not seeing any VPLMN
Hello all,
we are using FX-130 in Australia, where I do know there is LTE signal… As other modems are connecting with no issue using same SIM card.
ati
Model: FX30(WP7702)
Revision: SWI9X06Y_02.22.12.00 eaf79c jenkins 2019/04/24 18:48:27
IMEI: 354723090684902
IMEI SV:  3
FSN: VU251610190410
+GCAP: +CGSM
Not there is the SIM and readable and all
at+ccid?
+CCID: 89103900***********,89001*********************
at+cimi
2*********
But whatever I do, do not see any VPLMN
at+cops=?
+CME ERROR: no network service
at+cops?
+COPS: 0
at+creg?
+CREG: 0,2
When looking the technology and band selections do not see anything what would ring
at+ksrat?
+KSRAT: 9
at!gband?
!GBAND: B8     , 0000000000280180, 000000000A0F189F
at!impref?
!IMPREF:
 preferred fw version:    02.22.12.00
 preferred carrier name:  GENERIC
 preferred config name:   GENERIC_001.051_000
 current fw version:      02.22.12.00
 current carrier name:    GENERIC
 current config name:     GENERIC_001.051_000
at!priid?
PRI Part Number: 9907957
Revision: 001.000
Customer: FX30-Series
Carrier PRI: 9999999_9907787_SWI9X06Y_02.16.06.00_00_ATT_001.026_001
Carrier PRI: 9999999_9907618_SWI9X06Y_02.22.12.00_00_GENERIC_001.051_000
Carrier PRI: 9999999_9908788_SWI9X06Y_02.22.12.00_00_SIERRA_001.021_000
Carrier PRI: 9999999_9908088_SWI9X06Y_02.22.12.00_00_VERIZON_001.042_000
AT!GSTATUS?
!GSTATUS:
Current Time:  151              Temperature: 36
Modem Mitigate Level: 0         ModemProc Mitigate Level: 0
Reset Counter: 2                Mode:        ONLINE
System mode:   LTE              PS state:    Not attached
IMS reg state: UNKNOWN          IMS mode:    Not Support
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
LTE band:      B37              LTE bw:      Unknown
LTE Rx chan:   0                LTE Tx chan: 4294967295
LTE CA state:  INACTIVE
EMM state:     Deregistered     Attach Needed
RRC state:     RRC Idle
PCC RxM RSSI:  0                RSRP (dBm):  0
PCC RxD RSSI:  0                RSRP (dBm):  0
Tx Power:      0                TAC:         9F30 (40752)
RSRQ (dB):     0                Cell ID:     00000000 (0)
SINR (dB):     0
Is there anything I overlooked?!
Thank you for the help and best regards
T
What is the return of at!uims?
Probably you need to set AT!UIMS=0 to read the physical SIM
