Does anyone has experience in setup Fastrack Supreme 10 for electronic meter reading?
I use 2 GPRS modems. One modem is located on the server side named: TMAS GSM/GPRS (M39i-GPRS 10) and the other is located on the meter side named: Fastrack Supreme 10. The main duty of the server is to collect data of the meter (i.e. data energy, voltage, current). The connection between Fastrack and the meter is serial RS232.
So far, I have managed to setup both modems connect to GPRS network (on the same APN). Each modem will get IP address dynamically.
on the meter side:
AT+wipbr=3,6,15
+wipbr = 6, 15, “10.35.43.147”
on the server side:
cmd > ipconfig /all > IP: 10.35.7.4
For data communication between meter and server, should I create a particular channel for TCP/UDP on the meter side?
for instance: AT+wipcreate: 2,1,“10.35.7.4”, “2010”. so, The server (10.35.7.4) can get meter’s data via TCP/UDP channel.
I really appreciate any comments
