We are researching new hardware for our application and wondering if Fastrack Supreme can do what we want.
Can it read from RS-232 device and send the data over GPRS?
Can it use external sd-cart/mmc memory to save data and send it later?
What we need is the device that collect data from rs-232 port (1-wire adapter), save data to memory cart and send it via HTTP POST once GSM coverage is there.
Please advice if we can Fastrack Supreme for this task.
Unfortunately there are no local distributors for wavecom. Can you advice any online distributor?
I know there is work involved, currently we build such devices from etrax cpu (100mhz) and separate gsm/gps modem.
However maybe Fastrack Supreme can replace both and cut costs. I just want to figure out if Fastrack is suitable for the task before getting test unit.
Can we have custom C app running on the device and talk to UART1 periodically and save data to internal flash (128K ?).
Also GPS data should be collected similar way. Open AT OS is capable to doing multiple things, right?
External sd-cart looks like a trouble here…can we use SPI? Is there any driver in the SDK to support SPI mmc/sd-card?
There is no RS-232 port if GPS extension in use. So talking to RS-232 and collecting GPS data looks like impossible task for Fastrack Supreme.
Please correct me if I’m wrong.
