davidc
July 26, 2009, 1:12am
Hiya,
Does anyboy else think that it would be a good idea to have a FAQ area on either the Forum or Developer’s website?
I’ve noticed that the same questions are asked (and answered) over and over again. Topics like
I can’t find the SDK on the Wavecom website
How do I download firmware to the Wavecom Supreme using DWLWin
are just two that occur off the top of my head.
There’s an absolute wealth of info in the forum now, and it would probably be a good idea to abstract the common issues out to a single place.
ciao, Dave
awneil
July 26, 2009, 6:17am
There is already a FAQ area on the developer’s website:
wavecom.com/modules/movie/sc … n=listFaqs
Trouble is, it’s hard to find, hard to use, and the information is pretty sparse and out-of-date.
Very true.
Topics like
I think that’s just because the website design is poor. The website needs to be fixed!
And, as I’ve often said, that should be clearly documented in the “mainstream” documentation - not buried in a FAQ.
I do think that a FAQ is a good idea - but it mustn’t be used as an excuse for not fixing “mainstream” documentation…
eg, see:
viewtopic.php?f=47&t=1135
viewtopic.php?f=78&t=3437
davidc
July 27, 2009, 2:47am
Hiya,
awneil:
There you go - I didn’t know it existed. And yes, it is all of the above (lots of references to OAT-3.00!).
Exactly - although an electronic FAQ can be updated/maintained quicker/easier than the mainstream doco that is bundled with a Release.
Jamie - any thoughts?
ciao, Dave
awneil
July 29, 2009, 1:55pm
#4
The use of AT+CMEE=1 to get extended error info is certainly one for the FAQ
viewtopic.php?f=16&t=3780&p=14663#p14663
awneil
July 30, 2009, 3:34pm
#5
The dependence of certain facilities on having specifc “Commercial Features” enabled;
The trick of having a startup delay in your application - and all samples should do this
Although the 1st one is another that should be properly documented in the “main” documentation - not just buried in a FAQ.
awneil
September 22, 2009, 12:54pm
#6
The need to enable USB (and UART2) before it can be used:
wavecom.com/modules/movie/sc … 518#p15518
Update (2010) :
R7.4 (and later) opens the USB port automatically - this is a change from earlier firmware.
davidc
September 23, 2009, 12:20am
#7
awneil
September 23, 2009, 1:09pm
#8
awneil
October 1, 2009, 9:56am
#9
eg, viewtopic.php?f=37&t=3986&p=15720#p15717
viewtopic.php?f=30&t=2275&p=9244#p8408
It’s not “garbage” - it is PPP data.
The module has been asked to create an IP connection, so it expects the external device to respond with IP packets in PPP format.
Because it doesn’t get any PPP/IP packets, it drops the call - hence giving NO CARRIER .
The modem is working correctly!
davidc
October 16, 2009, 6:57am
#10
Hiya,
Don’t use the following code construct:
while(1)
// do something
See viewtopic.php?f=36&t=3908&start=15#p16093 amongst others.
ciao, Dave
awneil
November 11, 2009, 8:28am
#11
awneil:
See also: viewtopic.php?f=23&t=3922&p=16688#p15350
Example: viewtopic.php?f=16&t=4204&p=16686#p16686
davidc
November 11, 2009, 11:38pm
#12
Hiya,
Looks like a number of users are having strange or intermittent issues with their modules that end up being resolved by fixing the module PSU.
See here and here for a couple of examples.
Of course, there’s also the Power Supply forum to peruse as well.
ciao, Dave
awneil
November 12, 2009, 8:07am
#13
Yes, I’ve had such issues myself!
It’s not just the PSU itself - the connections to the module (especially ground) need to be absolutely “solid”
Example: viewtopic.php?f=123&t=5693&p=23827&hilit=vbatt+line+too+narrow#p23826
This is because all GSM devices have a very high supply current peaks - Wavecom quote over 2A !
Edit :
Just noted that I have already mentioned “Module Grounding ” in an earlier suggestion in this thread!
awneil
November 12, 2009, 9:32am
#14
awneil
November 28, 2009, 8:05am
#15
awneil
November 28, 2009, 2:16pm
#16
awneil
December 11, 2009, 10:50pm
#17
If the unit fails to register, check the Frequency Band setting - especially after a firmware update
see: viewtopic.php?f=53&t=4332#p17345
awneil
December 11, 2009, 10:52pm
#18
But note that R7.4 opens the USB port automatically - this is a change from earlier firmware.
davidc
January 1, 2010, 11:16pm
#19
Hiya,
Yet another common problem: Trying to make calls/connect to GPRS before SIM is initalised and network registered.
Always check SIM state and Network Registration before attempting network operations.
Check for SIM_FULL_INIT and +CREG: 1 responses…
See:
viewtopic.php?f=3&t=3422
viewtopic.php?f=29&t=3975
ciao, Dave
awneil
January 1, 2010, 11:55pm
#20
In fact, trying to do anything network-related before the network is ready!
SMS is another key one…
This one, of course, is not Wavecom-specific.
